Breather solution of the sine-Gordon equation
  • Thread starter Thread starter IanBerkman
The discussion centers on the breather solution of the sine-Gordon equation, specifically the equation $$u_{tt}-u_{xx}+\sin u = 0$$. Participants analyze the substitution of the variable separation form $$u(x,t)=4\arctan (\Theta(x,t)); \Theta(x,t)=A(t)B(x)$$ into the sine-Gordon equation. Key points include the incorrect definitions of $$\partial_t F(\Theta)$$ and $$\partial_x F(\Theta)$$, which should be expressed as $$\partial_t F(\Theta) = \partial_t(\Theta)\partial_\Theta F(\Theta)$$. The final expressions for $$u_{tt}$$ and $$u_{xx}$$ are also discussed, leading to the conclusion that further simplification using $$\tilde{A}$$ is necessary for clarity.
  • Understanding of the sine-Gordon equation and its applications
  • Familiarity with variable separation techniques in partial differential equations
  • Knowledge of chain rule in calculus
  • Experience with mathematical notation and transformations in physics
  • Study the derivation of breather solutions for the sine-Gordon equation
  • Learn about variable separation methods in solving partial differential equations
  • Explore the implications of the chain rule in the context of differential equations
  • Investigate the role of transformations in simplifying complex equations
Mathematicians, physicists, and students studying nonlinear dynamics or partial differential equations, particularly those interested in soliton theory and breather solutions.
IanBerkman
In a homework problem, the following statement is made:
Sine-Gordon equation for the field u(x, t) in dimensionless units reads:
Search for the breather solution in the form of variable separation:
a. Substitute the above equation into sine-Gordon equation. Transform derivatives of
arbitrariry function of ##\Theta## with the aid of ##\tilde{A}=A_t/A; \tilde{B} = B_x/B## in the following way:
$$\partial_t F(\Theta) = \tilde{A} \partial_\Theta F(\Theta), \partial_x F(\Theta) = \tilde{B} \partial_\Theta F(\Theta)$$
My question about this problem is if the definition given for ##\partial_t F(\Theta)## and ##\partial_x F(\Theta)## is true. Because chain rule gives:
$$\partial_t F(\Theta) = \partial_t(\Theta)\partial_\Theta F(\Theta) = BA_t\partial_\Theta F(\Theta) \neq A_t/A\partial_\Theta F(\Theta)$$
Furthermore, when it is substituted into the sine-Gordon equation, I obtain:
$$(A^2B^2+1)\tilde{A}_t-2\tilde{A}^2AB-A^3B^3=(A^2B^2+1)\tilde{B}_t-2AB\tilde{B}^2-AB$$
The LHS should become a function of A only, and RHS of B, but it seems like this is not possible.
These are the quantities I have used:
$$\sin u = \frac{-4(\Theta^3-\Theta)}{(\Theta^2+1)^2}\\
u_{tt} = \tilde{A}_tB\partial_\Theta u +\tilde{A}^2\partial_{\Theta\Theta}u\\
u_{xx} = A\tilde{B}_x\partial_\Theta u +\tilde{B}^2\partial_{\Theta\Theta}u $$
where
$$\partial_\Theta u = \frac{4}{\Theta^2+1}\\
\partial_{\Theta\Theta} u = \frac{-8\Theta}{(\Theta^2+1)^2}$$
I agree that what is written above is not correct. To see what they should have written, you have shown
$$\partial_t F(\Theta) = \partial_t(\Theta)\partial_\Theta F(\Theta) = BA_t\partial_\Theta F(\Theta)$$
Simplify the last expression by writing it in terms of ##\tilde{A}##, ##\Theta##, and ##F(\Theta)##.
$$\sin u = \frac{-4(\Theta^3-\Theta)}{(\Theta^2+1)^2}$$
OK
$$u_{tt} = \tilde{A}_tB\partial_\Theta u +\tilde{A}^2\partial_{\Theta\Theta}u\\
I get something different for ##u_{tt}## and ##u_{xx}##.
where
OK
This could be true since I have used the "wrong" derivatives in the problem.
I have converted it to:
$$u_t=A_t B\partial_\Theta u\\
u_{tt} = \partial_t(A_t B \partial_\Theta u) = \partial_t(A_t B)\partial_\Theta u + A_tB\partial_{\Theta}(\partial_t u)\\
=A_{tt}B\partial_\Theta u + A_t B \partial_{\Theta}(A_t B\partial_\Theta u)= A_{tt}B\partial_\Theta u + (A_t B)^2 \partial_{\Theta\Theta} u$$
I think you will be better off expressing these in terms of ##\tilde{A}##.
For example, take ##u_t=A_t B\partial_\Theta u##. Can you express this in terms of ##\tilde{A}## (without any explicit appearance of ##B##)?
That would indeed be ##u_t = \tilde{A}\Theta \partial_\Theta u## and ##u_{tt} = \tilde{A}_t\Theta u_\Theta + 2\tilde{A}^2\Theta u_\Theta + \tilde{A}^2\Theta^2u_{\Theta\Theta}## if I calculated correctly (it is a bit late now and I am a bit sleepy).
This looks a lot more appropriate and I will proceed tomorrow to work out the sine-Gordon equation.
IanBerkman said:
That would indeed be ##u_t = \tilde{A}\Theta \partial_\Theta u## and ##u_{tt} = \tilde{A}_t\Theta u_\Theta + 2\tilde{A}^2\Theta u_\Theta + \tilde{A}^2\Theta^2u_{\Theta\Theta}## .
OK, except I'm not getting the factor of 2 in the middle term of the expression for ##u_{tt}##.
Sounds good.
Yes I saw where the mistake came from, I am going to revise everything a bit tomorrow when I am a bit more fresh.
