M11
- 14
- 0
Why the output DC voltage of the center trapped rectifier is half that of a bridge rectifier??
The output DC voltage of a center-tapped rectifier is half that of a bridge rectifier when using the same transformer primary-to-secondary ratio. In a center-tapped configuration with two diodes, only half of the total secondary voltage is rectified during each half cycle. Conversely, a bridge rectifier utilizes four diodes to rectify the full secondary voltage on each half cycle of the mains waveform. This conclusion holds true even if the center-tapped transformer has a total secondary voltage that is double that of the bridge rectifier, excluding diode voltage drops.
PREREQUISITESElectrical engineering students, circuit designers, and anyone interested in power electronics and rectification methods.
