Brittle Materials: Bending Yield Strength
The discussion revolves around the yield strength of brittle materials, particularly in the context of bending tests. Participants explore the complexities of measuring yield strength in brittle materials, especially when subjected to conditions such as heating and confining pressure, and compare these methods to traditional tensile tests.
  • Some participants propose that the ultimate strength of a brittle material can be determined through bending tests, but question how yield strength can be assessed given that brittle materials typically fail before significant flow occurs.
  • One participant suggests that yield can be defined as the ability of a material to return to its original shape after unloading.
  • There is mention of ASTM C1161, which specifies a constant loading rate for bending tests, but some participants express uncertainty about its applicability to hot bending tests.
  • It is noted that heating a brittle material can reduce its yield strength, and that bending tests are often used to ensure a certain level of ductility for formability or performance reasons.
  • Participants discuss the complexity of measuring yield stress in bending tests compared to uniaxial tests and express interest in evaluating yield estimates at high temperatures and under confining pressure.
  • One participant considers the possibility of using a hot triaxial test as an alternative method for assessing yield strength in brittle materials.
Participants do not reach a consensus on how to effectively measure yield strength in brittle materials, with multiple competing views and approaches remaining in the discussion.
Participants highlight limitations in existing standards and methods, particularly regarding the absence of provisions for hot tests in ASTM C1161 and the challenges of measuring yield in bending tests compared to uniaxial tests.
1350-F
It seems to me that the ultimate strength of a brittle material can be easily determined by a bending test, but what about the yield? In the brittle regime, I can see how you couldn't, since the sample would fail before it would flow significantly. However, brittle materials can be made to flow a little bit by heating, confining pressure etc. In a hot bending test for example, is there a measure of the yield?
Isn't the measure of yield: If you release the loading on the body, it returns to its original shape.
Chet
Chet
Hmm. I suppose you could do an incremental bending test. ASTM C1161 calls for a constant loading rate. I'll go looking for a standard that includes it.
Thanks.
Most often tensile tests are uniaxial, or biaxial. Heating (increase in temperature) reduces yield strength.
Bend tests are usually performed to assure a certain level of ductility (usually for reasons of formability or performance). What is the purpose of ASTM C1161?
Measurement of yield stress in a bend test can be done, but it is rather complicated compared to a uniaxial test.
http://en.wikipedia.org/wiki/Flexural_strength
Taking another look at C1161, there's no provision for hot tests. I can see also how finding the yield wouldn't be the point. At the root of my question was: How can I evaluate a yield estimate for a brittle material? I am, like you say, interested in a yield at high temperature which will be lower and at enough confining pressure that the material is likely to flow. I thought there would be some info from the bending test (if it did become ductile at that temp alone) since its fairly common compared to the uniaxial test. Otherwise I thought a hot triaxial test would be appropriate, a sort of creep test under confining pressure.
  • · Replies 16 ·
