tovisonnenberg
- 19
- 1
Why wouldn't a brown dwarf grow in radius if it started to gain mass?
Brown dwarfs exhibit unique mass-radius relationships due to quantum mechanical effects known as degeneracy pressure. When mass is added to a brown dwarf, it can initially shrink until hydrogen fusion begins, at which point it expands due to the heat generated. Brown dwarfs with masses between 13 and 60 Jupiter masses (Mj) can initiate deuterium fusion, while those between 60 and 90 Mj can trigger hydrogen and lithium fusion, categorizing them as spectral class L, T, or Y based on temperature. Below 1000K, a brown dwarf is reclassified as an ordinary planet.
PREREQUISITESAstronomers, astrophysicists, and students interested in stellar evolution, brown dwarf characteristics, and the physics of celestial bodies will benefit from this discussion.
Why do you think it wouldn't? Here on PF it is bad form to just make a bald statement like that without citing where you are getting your informaiton. Are there particular conditions under which it wouldn't and some under which it would?tovisonnenberg said:Why wouldn't a brown dwarf grow in radius if it started to gain mass?
Tritium is short-lived and rare in nature.Chronos said:Adding mass to a degenerate body would cause it to shrink only so far as nothing else changes. For a brown dwarf, that something else would be hydrogen fusion. Once that occurs, the shrinkage would cease and it would expand due to the heat. A brown dwarf can remain degenerate, but initiate tritum fusion,at around 60 Jupiter masses [Mj].
So which do they and do they not initiate?Chronos said:At a mass around 13 Mj deuterium fusion is believed possible. Brown dwarfs in the 60-90 Mj] qualify as L spectral class, hot enough to initiate hydrogen fusion, but enough to trigger lithium fusion.
That's probably an arguable question of classification. Some white dwarfs are known to have cooled to 4000 K, yet they are called white dwarfs rather than red dwarfs.Chronos said:Brown dwarfs in the 13-60 Mj range are capable of deuterium fusion, but, not hydrogen or even lithium fusion. They are considered spectral class T or Y, depending upon temperature. Once the temperature falls below about 1000K it is no longer considered a brown dwarf, just an ordinary planet.
