Build High Speed Winch: 350lbs, 10ft/sec, Control Speed
To build a high-speed winch capable of lifting 350lbs at 10 feet per second, a minimum of a 6.4hp motor is required, which translates to a current demand of at least 400 amps at 12V, making it impractical. The discussion suggests considering lower speeds or higher voltage options to achieve the desired performance. Hydraulic systems are typically used for such applications, but the project constraints limit the use to electric power only. A 3 hp motor may not suffice for the specified requirements. Overall, the feasibility of the project needs reevaluation based on power and speed limitations.
Ryand
I am trying to figure out how to build a high speed winch. I need to be able to lift about 350lbs at a rate of 10 feet per second. I also need to be able to control the speed. I have power on site. I have been looking at a 3 hp 12 v dc motor and try to gear it to get the speed I need. Am I going the right direction?
To lift 350lb at 10ft/s will require the use of at least a 6.4hp motor. At that power with 12V the current required will be at least 400AMPS. Sounds a bit impractical. Perhaps go for lower speed or higher voltage.
Usually winches like this are hydraulic. Is that a possibility or is electric the only route available?
I can only use electric for this project.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
