Build a Capacitor in 30 minutes
A rolled capacitor design using aluminum foil as the conductor and saran wrap as the dielectric is deemed effective for the materials available. The design should incorporate a one-inch spacing around the edges of the foil to prevent arcing. A paper roll can serve as a suitable mandrel for rolling the capacitor. Additionally, the paper can be utilized as an outer covering for added insulation. This approach effectively incorporates all provided materials while ensuring functionality.
kat5657585950
Hi! I have to build a capacitor out of the following materials: 10 square feet of aluminum foil, 10 square feet of saran wrap (polyvinyl chloride), several sheets of paper, and tape to put it all together. I will only have about 30 minutes to manufacture my design. I have been researching capacitors and so far the best one I have come across using my given materials is a rolled capacitor. Is this accurate? Or is there a better one I have not come across? For this rolled capacitor I would probably only use the foil as my conductor and the saran wrap as my dielectric because, to my knowledge, it has a much higher dielectric strength than paper. The reason I am second guessing my design is because it does not use one of my given materials, paper. Is there a way i could work this in? Or a different design that uses all of my materials? Thanks!
I have decided on the rolled capacitor, but now I have more questions. How much spacing should leave around the edges of the foil on the saran wrap to avoid arcing? Is one inch sufficient? Also, I saw something about using a nonconductor like glass or plastic as a mandrel to lay in the center and roll up in the capacitor. Would a paper roll work well as this? Thanks again!
One inch border should be fine. The plastic wrap would probably punch thru long before you reach a voltage to flashover two inches!
An additional way to use the paper is as an outer covering.
  • · Replies 22 ·
