Building a device which will climb a length of string/wire
A user seeks to build a device that climbs a 2-meter string using the energy from a descending 200g mass. The proposed design involves gears secured to the string, utilizing frictional forces for movement. Key considerations include ensuring the kinetic energy from the falling mass is sufficient to lift the device while accounting for friction and gear ratios. Suggestions highlight the importance of balancing forces and calculating the maximum mass of the climbing part based on gravitational potential energy. The discussion also references concepts like differential chain hoists for inspiration.
yuanisgay
Hey guys,
I need to build a simple device that climbs a length of string (about 2 metres) without any support from above, and with energy from only the descend of a 200g mass. Speed is of importance.
I have considered using two pieces of gears secured onto the string with rubber bands tieing the middles of the gears together. and then, wind the middle part of the gears with strings and attach a mass to the strings. when the mass is allowed to drop, it will give the gears rotational energy and climb up the string, using frictional forces.
I am wondering if this could work? How can I improve it if it does, and how can I change it if it doesn't?
New ideas are also welcome!
Thanks!
If you want to elevate something with the weight of a mass then you need to make sure the the force are balanced, in the sense that the kinetic energy of the falling mass must be enough to elevate the mass upwards. Without this precondition your mechanism will simply not work. After that, i must gears involve additional work regarding frictions and multiplication ratios.
If you have all this worked out can you give us some more specifics, like mass of the climber, what kind of wire etc
Depends, if this is about the UBC contest, it is over and done with.
If there is some other contest in mind... The centre of mass of the system must head downwards, making gravitational potential energy available to be converted into kinetic energy and overcome frictional losses in your gears, bearings and other bits.
A light part climbs up while the mass drops. You can easily calculate the maximum mass of the light climbing part by conservation of gravitational potential energy.
Leave a message if this contest is still a going concern.
Look at how a differential chain hoist works. A 200-g weight descending 4 meters can easily power a device that climbs 2 meters of string.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
