Building a digital clock with 555 timer and BCD decoder
  • Thread starter Thread starter bravo92
    Clock Digital
6 replies · 3K views
bravo92
I want to make a digital clock on hardware using 555 timer and BCD decoder to 7 segment display. Can anyone help me about the circuit ?
I am using the concept to increment the input of BCD decoder with the help of 555 timer but don't know how to do so
Do you mean a 24 hour clock that tells human time or a 7-segment display that goes 0-9 and repeats?
You would need a BCD counter between the 555 and the decoder.
The 555 would connect to the clock of the BCD counter and the output would be converted by the decoder into drive for the 7 segment display.
@antiphon : I want to make a 7 segment display that goes 0-9 and repeats ... and for hours , minutes as well as seconds ...
@vk6kro : how to increment the counter that runs the clock ?
The counter will increment on each rising edge of the square wave from the 555.
So, you can arrange the incrementing rate by adjusting the oscillation frequency of the 555. (you do this by selecting the components that determine the frequency. Making both resistors 470 K and the capacitor 1 uF will get a frequency of about 1.02 Hz)
If you are trying to make this look like a real clock, don't forget that the seconds and minutes counters will go to 59 and then to zero, and the hours counter will go to 12 and then to one.
You are not going to get a very accurate clock circuit using a 555 timer chip. A better solution would be to use a CD4060 or 74HC4060 IC and a 32.768kHz watch crystal. Here is a simple Google search that includes circuit info and a YouTube video:
http://www.google.com/webhp?sourcei...sb&fp=89a2241ee9b71d7a&ion=1&biw=1149&bih=882
