Building infinity corrected microscope from non-infinity corrected objective
Using non-infinity corrected objectives in infinity corrected microscopes is generally inadvisable due to significant issues like degraded image quality and improper back focal plane positioning. The discussion explores the feasibility of building an infinity corrected microscope from scratch using non-infinity corrected objectives, questioning whether proper placement could maintain infinity correction. However, it is anticipated that such a setup would lead to considerable distortion and field curvature, undermining performance. The advantages of infinity-corrected systems, such as maintaining focus with additional optical components and simplifying aberration balancing, highlight the challenges of using non-infinity corrected lenses. Overall, the consensus suggests that non-infinity corrected objectives would not perform adequately in an infinity corrected optical setup.
anandr
Hi there
As is known using non-infinity corrected objectives in infinity corrected microscopes is not a good idea because of many reasons (image quality will be degraded, back focal plane will be in wrong place, parfocal distance is not preserved, etc.).
What about building infinity corrected microscope from the scratch using non-infinity corrected objective: is it possible? Are there any design differences between the two kinds of objectives that does not allow this or at least have to be handled properly?
Anyway, references to microscope design books are highly appreciated.
Likes iRandy
Doing that would be incredibly painful- why not start with an infinity corrected objective lens? There are two major benefits to infinity-corrected microscopes:
1) Putting optical components (polarizers, beamsplitters, waveplates, etc) in 'infinity space' does not change the optical path length, so your object remains in focus as these components are inserted or removed
2) aberration balancing can be performed with the tube lens- the objective lens doesn't have to be fully corrected, resulting in a simpler (less expensive) lens. This unfortunately means that, for example, non-Leica objectives can't be used in a Leica microscope (as opposed to the non-infinity corrected objectives which can be used in any microscope)
Hi Andy
Thanks for your reply. Sorry if my question was not clear enough but it seems to me that you misunderstand it a little so I'll try to rephrase it.
I'm not asking about replacing an objective in already made microscope but rather about building microscope from spare components by myself so I can place elements at any distances from each other. Unfortunately the lenses I'd like to use are not infinity corrected (Murphy's law).
I understand why infinity optics is better. To be simple it looks like this:
1) object (placed in focal plane of the objective lens)
2) infinity-corrected objective lens
3) "infinity space" = parallel beams = right place for additional components
4) tube lens
5) image (located in focal plane of the tube lens)
Imagine that we replaced the "infinity-corrected objective lens" with "non-infinity-corrected one" but properly placed so its focal plane also coincides with the object and it will also produce parallel beams after it. It seems that this setup should remain "infinity corrected". But how it will perform in this case? How much image quality will degrade and what about aberrations?
So my question is:
If objective was initially designed for non-infinity-corrected setup then does it perform equally well when placed properly in infinity-corrected optical setup?
anandr said:
Hi Andy
<snip>
So my question is:
Probably not. I expect there will be a lot of distortion and field curvature.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
9K
