Bullet through block and spring
The problem involves a bullet passing through a block connected to a spring, focusing on the conservation of momentum and energy principles. The bullet's mass is given, along with its initial speed, and the block's mass and spring constant are also provided. The task is to find the bullet's exit speed and the energy lost during the collision.
  • Mixed
  • Participants discuss using conservation of momentum and energy to analyze the problem. Some express confusion regarding the application of energy conservation due to potential energy losses in the system, such as thermal energy and sound. Others suggest drawing diagrams to better understand the forces at play.
The discussion is ongoing, with various participants exploring different aspects of the problem. Some have provided links to similar problems, while others are questioning the assumptions made regarding energy conservation. There is recognition of the need to separate momentum and energy considerations in the analysis.
Participants note that kinetic energy is not conserved during the collision, which complicates the use of energy conservation equations. The problem is framed within the context of a homework assignment, implying certain constraints on the approach to finding solutions.
dkgojackets
A bullet of mass 9 g moving with initial speed 300 m/s passes through a block of mass 4 kg, initially at rest on a frictionless, horizontal surface. The block is connected to a spring of force constant 904 N/m. If the block moves 2 cm to the right after the bullet passed through it, find the speed at which the bullet emerges from the block and the magnitude of the energy lost in the collision.
Conservation of momentum.
Well initial mometum is just (.009)(300), and it must equal (.009)(Vf)=(4)(Vblk)
to solve for the block velocity immediately after the bullet passes, I used Vf = sqrt(2ad). I said acceleration was (904)(.02)/(4)...(may be where I went wrong). I took that velocity and plugged it back into the original momentum equation and got velocity of the bullet to be 111 m/s, which was wrong.
First draw a basic idea of how this looks; a good force body diagram or a diagram on how this works. Drawing out what happens can get you far when conceptualizing what happens and going about problems.
After you do this, we can start working on the problem :).
But here's a few things to think about:
There's a few things to deal with this such as momentum [bullet through the block] and energy [spring energy].
Kurdt said:
This is an energy question. There have been many similar threads. From the two links below I'm sure you can work out what you need to do for this question.
https://www.physicsforums.com/showthread.php?t=146628&page=3&highlight=bullet+in+block
https://www.physicsforums.com/showthread.php?t=148204&highlight=bullet+in+block
I used conservation of energy (initial KE of bullet = final KE of bullet + spring potential), but I got almost the exact same speed for the bullet. Not even .1 m/s less.
Kinetic energy is not conserved during the collision. This problem involves both conservation of momentum and conservation of energy--separately. (See the links that Kurdt provided.)
If you show the work you have done we can determine where you are going wrong.
EDIT: Doc Al beat me
To go along with this.
The reason why you can't use conservation of energy is due to the fact that there maybe thermal energy caused by this or sound and other various forms of energy. Energy is not conserved. Conservation of energy only works with perfectly elastic or a complete inelastic collision.
As I stated in my post there are things at work here =). Spring energy being one and the momentum.
:bugeye: :eek:
I get that momentum is conserved during the collision, and mechanical energy after. But why would conservation of energy not work if I have just one unknown in the equation?
.5(.009)(300^2) = .5(.009)(v^2) + .5(904)(.02^2) is my energy conservation equation.
What about thermal energy? Sound...?
I got it now. The bullet into the block gives the block a kinetic energy, which is immediately transferred into the spring. I know the spring potential energy and used it to solve for the velocity of the block immediately after the collision, which I put into conservation of momentum equation.
