Is My Buoyant Force Calculation Correct?
The discussion centers on calculating the buoyant force for a hot air balloon with a volume of 2107 m³ and a total weight of 1832.6 N. The participant correctly deduced that the buoyant force must equal the gravitational force for the balloon to float level, leading to the conclusion that the density difference required for buoyancy is 0.0888 kg/m³. However, the participant's approach lacked clarity in defining variables and steps, prompting suggestions to use an unknown density for the cold outside air (ρ_c) and express the hot air density in terms of the density difference (Δρ) for a more rigorous solution.
  • Understanding of buoyant force calculations
  • Familiarity with density concepts in physics
  • Knowledge of gravitational force equations
  • Ability to manipulate algebraic expressions
  • Study the principles of buoyancy and Archimedes' principle
  • Learn how to derive density differences in fluid mechanics
  • Explore the implications of temperature on air density
  • Practice solving buoyancy problems with varying conditions
Students studying physics, particularly those focusing on fluid mechanics and buoyancy, as well as educators looking for clear explanations of buoyant force calculations.
hanag
A recreational (open) hot air balloon (i.e., Pinside is approximately Poutside) has a volume of 2107 m3 when fully inflated. The total weight of the balloon, basket, ballast and pilot is 1832.6 N (412 lbs). By how much must the density of the air in the balloon be smaller than that of the surrounding atmosphere in order to keep the balloon floating level near the ground?
Buoyant force= volume x g x rho
I got the right solution, but it was explained much differently in class (much more complicated), and I didn't even use all the values given in the problem. I'm not sure if my logic is correct.
I figured that the buoyant force must be equal to gravity because the balloon is not accelerating.
v x rho x g = m x g
2107 m^3 x rho x g= 1832.6 N
2107 m^3 x rho = 187 kg
difference in rho= 0.0888 kg/m^3
Does what I did make any sense at all? Thanks in advance!
The logic is a little loose even though the answer is probably right.
You label the density by rho in the buoyant force. And then you change the meaning to a density difference. This is not good practice and is missing some steps.
So how would I go about doing this the right way? I don't even know where to start.
Put in an unknown density for the cold outside air, ##\rho_c##, and write the thing you want to find, the difference, as ##\Delta \rho##. In terms of those write the density of the hot air. Then write an expression for the buoyant force in terms of those, and observe the cancellation of the unknown ##\rho_c##.
