Buoyant Force on a Helium Balloon
11 replies · 19K views · last reply
e(ho0n3
A helium balloon has volume V0 and temperature T0 at sea level where the pressure is P0 and the air density is [itex]\rho_0[/itex]. The balloon is allowed to float up in the air to altitude y where the temperature is T. (a) Show that the volume occupied by the balloon is then V = V0(T/T0)ecy where [itex]c = \rho_0g/P_0[/itex]. (b) Show that the buoyant force does not depend on altitude y. Assume that the skin of the balloon maintains the helium pressure at a constant factore of 1.05 times greater than the outside pressure. [Hint: Assume that the pressure change with altitude is P = P0e-cy].
The ideal gas law and the buoyant force equation.
(a) is pretty simple since the hint gives it away. What concerns me is (b). Since the buoyant force on the balloon is equal to the weight of the volume of air displaced by the balloon, and since the volume depends on altitude, then it seems logical that the buoyant force depends on altitude. What gives?
But the density of the air decreases with altitude. What matters is how the product density*volume--the weight of the displaced air--varies with altitude.
The mass of air inside the balloon remains the same regardless of its change in volume. Thus, the buoyant force is constant right? (Actually, it wouldn't since the force of gravity decreases with altitude.)
Yes, the mass of the helium remains the same, but the buoyant force equals the weight of the displaced air, not the balloon contents.
Ah, OK. I was getting confused. Let [itex]\rho = m/V[/itex] be the density of air at altitude y; m is the mass of air displaced by the balloon whose volume V is as given in the problem statement. The buoyant force is [itex]\rho V g = mg[/itex]. Hmm...so now how do I know that m is always the same?
Applying the ideal gas law to air, then
[tex]PV = P \, \frac{m}{\rho} = nRT[/tex]
Rearranging yields
[tex]\rho = P \, \frac{m}{nRT}[/tex]
The fraction m/n is surely constant as it equals air's molar mass. Now what about P/T? If they both decrease at the same rate, then it will definitely be constant. I don't have an expression for T though.
Keep going. Now find the buoyant force, which is:
[tex]\rho g V[/tex]
If I substitute and simplify, I get that the buoyant force is mg which is what I had derived in post #5. Again, I don't know if m is constant though.
What matters is how the density of the air varies. From the ideal gas law, the density of air will be proportional to:
[tex]\frac{nR}{V} = \frac{P}{T}[/tex]
Plug that into the expression for buoyant force.
I see. You're suggesting that the buoyant force is proportional to nRg right? However, like m, doesn't n depend on altitude as well?
All we are concerned with at this point in the solution (as in post #10) is what the air density depends on. I'm not concerned with any particular mass of air or number of moles.
It will turn out that the mass of air displaced by the balloon is independent of altitude, but no need to assume that at this point.
