Busting the myth about achieving artificial gravity by rotating a body
38 replies · 4K views
lolsurround
TL;DR
TL;DR our idé of artificial gravity is flawed
Movement isn't required to achieve gravity, even the artificial kind. Standing on a rotating body requires you to be actually physically standing on it. How is this achieved? Well, by gravity of course. Unless you are tied/stuck to the rotating body, but in that case there is no gravity pushing you down on the rotating body in the first place, if you're in space.
If we assume we are stuck to the rotating body by using a pair of magnetic boots, every time we deactivate the boots we would be floating freely in space. The rotating ground below us would just fly by without us stuck to it. For centripetal for to exist there has to be gravity in the first place, thus making the whole idé of artificial gravity using a rotating a body, by nature, flawed.
  • Haha
If you are on the inside of a rotating cylinder in deep space and you jump you will definitely land on the inside of the cylinder again. Because you move in a straight line (as seen in an inertial frame) and that inevitably intersects the cylinder again.
This is nonsense. The type of artificial gravity you describe is designed to work in space and there basically is no gravity, just the downward force on your body as the ring you are standing on rotates creating artificial gravity.
lolsurround said:
... the whole idé of artificial gravity using a rotating a body, by nature, flawed.
Tell that to this guy:
  • Love
Yes you will land on the inside again, but you're wrong about the fact that it will keep you on the floor. Even if you're moving along the cylinder in its inertial frame, you won't be pulled towards it. It will hit you again and again and you will have to hold on to it in order to keep moving along with it.
But don't you understand what is causing the downwards force that you speak of in the first place? It is centripetal force and that "force" can only exist with gravity.
Depends on your frame of reference. In a rotating frame, yes you will. In an inertial frame, the floor comes up to meet you.
Or "friction" as we usually call it.
lol thanks for proving my point!
There is no force of gravity. That's a Newtonian myth!
That whooshing sound you hear is that gag flying over @lolsurround's head...
Doesn't matter what you call it. Where would your friction come from?
Ibix said:
That whooshing sound you here is that gag flying over @lolsurround's head...
Well isn't this a pleasant forum where you can have discussions with adults without making fun of each other :)
or "hear" as we usually call it...
The floor sliding under your feet, if you aren't travelling at the same linear velocity as the cylinder edge.
There's a serious point underlying it, which is that what we usually interpret as "the force of gravity" is actually the exact same kind of inertial force you're denying exists in the rotating frame case.
And you flagged this as A level (edit: I see it's now been changed to B level) meaning you claim graduate-level knowledge of this topic. You open yourself to a bit of ribbing when you make such a claim when you obviously don't have anywhere near that grasp of the topic.
That's where the issue is. You can't stand upright on a sliding floor under your feet unless you are pulled down on that floor. Doesn't matter how much friction you have. Let's say you have enormous friction between your shoes and the floor. Since there's no force pulling you down, how will you stay upright along that floor? Your shoes will just pull your lower body towards the direction the sliding floor is going.
You're right that artificial gravity is, technically, a fictitious force. But, so is the real thing (the Earth's gravity is a fictitious force). One fiction replaces another.
...or if the floor somehow curves upwards and pushes up on your feet.
Is this a serious thread?
Is the OP actually arguing that artificial gravity by dint of rotation does not happen?
It's a stupid flag system in my view t.b.h. I don't claim to have A level knowledge, but i thought this would be interesting to discuss with someone who has graduated in physics.
OT: Isn't the force of gravity caused by mass? Not by rotating objects?
We have centrifuges in space. They work just fine.
Yes and yes. That's exactly what i'm saying.
  • Haha
Then maybe ask questions about what you don't understand instead of making unsupported claims.
Making unsupported claims from a lack of knowledge is not the PF way.
No. It's not a force. The force you feel is caused by the floor accelerating upwards into your feet, exactly the same way that the rotating cylinder floor curves upwards and pressed on your feet.
Of course we have that. I'm not arguing that centripetal force isn't a real thing. The surface tension of the blood keeps friction in the tube, causing it be pushed outside. Notice how it's tilted inside the centrifuge? It's like that for a reason.
  • Haha
  • Skeptical
If you examine an astronaut in a closed rotating system that has air - from an external non-rotating reference frame - you will quickly see how the astronaut is drawn toward the outer wall and contacts it after a short time.
From the astronaut's point of view, this behaves sufficiently like gravity to do its job. i.e. Keep your feet on the floor and your milk in your glass.
Where is the disconnect?
lolsurround said:
TL;DR Summary: TL;DR our idé of artificial gravity is flawed
This is simply false. Do not repeat this assertion nor any similar false claims. The physics of centrifuges is well understood.
Start with a guy in a non- rotating centrifuge with your magnetic boots. Let the centrifuge begin rotating. The guy in the boots will feel a tug as the rotation starts, then he will start gradually feeling “weight” as the centrifuge comes to speed. Once it is at speed he can turn off the magnets and he will continue to feel weight. He can jump and he will leave the ground, feel weightless briefly, and fall back to the ground. With a sufficiently large centrifuge the Coriolis force would be small, but smaller centrifuges would have larger Coriolis forces. Those would make the fall deviate from a standard parabola, but not usually to the point of not falling back to the floor.
You are. If you don't realise that's what you're doing that's the thing you need to work on understanding.
https://spaceplace.nasa.gov/what-is-gravity/en/
You're wrong. The fact that gravity isn’t the same everywhere on Earth is a direct consequence of this.
  • Sad
This is not how intelligent discussion goes on PF. Ask questions rather than make assertions.
(How long is this going to go on before the thread is locked? 🤔 )
Why would it get locked for asking a legit question?
  • Skeptical
  • Haha
