But I'm sure Speed and velocity are the same thing
  • Level: High School
  • Thread starter Thread starter Weissritter
    Speed Velocity
38 replies · 7K views
Weissritter
Yeah, I know the differences between speed and velocity. In common life, however, I may use them as if they were the same. Guess my science-brain isn't that much active sometimes.
While this thread is physicist-targeted, anyone's reaction is welcome.
You know the difference between those two words, right? How do you feel when common people use them as if they meant the same? Have you ever objected at their actions, or you just sigh again, as if no effort could stop the misuse?
Velocity as a vector quantity versus speed as a scalar quantity (magnitude of the velocity) is purely a convention among physicists. I learned just today that it appears to have been started by J. W. Gibbs around 1901. He wrote the first textbook (as opposed to lecture notes) that taught the vector mathematics that we use today.
When I'm dealing with non-physicists in a non-physics context, I don't expect them to know the difference, nor do I make a point of it.
The one thing that does get me is when lay persons try and tell me deceleration is not acceleration.
Pythagorean said:
I don't expect laymen to recognize the distinction.
Same here, and I try not to let them see my eye twitch.
I very rarely hear anyone say velocity. I almost always hear then say speed, but I rarely have issue if they misuse it outside of a technical environment.
I get more upset when people mix up your and you're on Facebook.
Some people just don't realize "your" is scalar and "you're" is a vector.
For now we have no murder desire, so it is kinda good. When it comes to your and you're things do become more annoying.
Do we have more opinions?
In nonacademic talk, I pretty much use speed exclusively.
And that "your'e" is imaginary.
I don't feel bad when someone misuses velocity for speed, my brain just pops up a "wrong" message. The same happens when I hear/read "weight ... kg".
Greatest line ever.
Or using "lightyear" as a measure of time.
This gives me a controllable murder desire
Also forgot the highest one: saying "degrees kelvin" The worst part is that most people who say this are not common non-physicist. They are usually scientists, who are supposed to know this. It becomes worse when something as big and inspected as "The Avengers" makes that mistake. :mad::mad:
So wait. Should we be using the term "escape speed" instead of "escape velocity" now?
Just askin'...
Just askin'...
But in this case direction matters.
This confusion is our fault rather than a confusion in the lay community. The technical world is the one that had a problem with the term "weight", not the lay community. This technical confusion wasn't resolved until 1901 when, by dint of a bureaucratic decision, weight was deemed to denote "a quantity of the same nature as a 'force'."
The lay community was and is just fine with weight being a non-technical synonym for the technical concept of mass. Legally, the term "weight" is still a synonym for mass in the US. A one pound can of beans weighs one pound at the South Pole, at the tip of Mt. McKinley, and even on the International Space Station.
Pythagorean said:
or "mass.. lbs"
A pound is a unit of mass. Perhaps you are confusing the pound with the pound force.
No it doesn't. That was berke making fun of our physicist friends:
The term escape velocity is actually a misnomer, and it is often more accurately referred to as escape speed since the necessary speed is a scalar quantity which is independent of direction (assuming a non-rotating planet and ignoring atmospheric friction).
http://en.wikipedia.org/wiki/Escape_velocity
russ_watters said:
No it doesn't. That was berke making fun of our physicist friends: http://en.wikipedia.org/wiki/Escape_velocity
Remember, escape speed is the speed needed to escape to infinity and as the distance approaches infinity, the angle between your motion and the Earth's center approaches zero, making every path essentially vertical.
Try down. That's a direction.
As long as there's nothing in the way, the trajectory can initially be in any direction, including down. Evacuating a tunnel through the center of the Earth is an engineering problem, not a physics one. :biggrin:
I thought the slug was the unit of mass in FPS?
They're equivalent in US. Slug is the unit of mass (m), lbs is weight (mg), pressure is lbs/in^2 (pounds per square inch)
Nobody ever says pound force.
Also, nobody ever says slug because there is no distinction between mass and weight in US laymen.
Also because the slug was added to the units of measurement later than the pound (mass). The term didn't come into common use until the 1920's (common being a very relative term, since pounds (mass) is still more common). Prior to being called the 'slug', the slug was called the 'geepound'. And, prior to the 1890's (approximately) people just used pounds.
I think (but really don't know) that the slug came about to make the US Customary system fit better with standard equations, such as F = ma. With slugs, you can use the actual rate of acceleration in ft/sec^2 instead of a ratio comparing the local gravitational acceleration to the standard gravitational acceleration at the surface of the Earth.
I am a laymen and may as well take this opportunity for one of you to educate me on the difference.
Mass and weight.
Velocity and speed.
Please give me an example of where each of these should be used.
A man weighs 160lbs.
A car travels at 60mph.
But I don't understand when to use velocity and mass.
Why? You expect people to express their weight in Newton or state what their mass is?
I'm cool with people using speed for velocity in a non-academic setting, but I'm less happy with people using velocity when they mean speed. It's usually a sign that they're trying to sound fancy by (mis)using a less common word.
Mass and weight.
Velocity and speed.
Velocity is just speed with a direction.
A car travels at 60 mph. That's speed.
A car travels at 60 mph north. That's velocity. A car travels at 60 mph to the right. That's also velocity.
Mass is a property of matter. Every single thing has mass. For example: a ball might have a mass of 3 kg (or 0.21 slug if you want to use the FPS system).
A force is a push or pull that causes any object to change its movement or direction. Weight is a force by gravity.
Newton's Second Law:
[tex]Force\quad (such\quad as\quad weight)=mass\quad x\quad acceleration\\ Therefore,\quad Weight=mass\quad x\quad g\quad (g\quad represensts\quad acceleration\quad caused\quad by\quad gravity)\\ Weight=(3\quad kg)(9.8\quad m/{ s }^{ 2 })\quad (g\quad is\quad 9.8\quad m/{ s }^{ 2 }\quad at\quad sea\quad level)\\ Weight=29\quad \frac { kg*m }{ { s }^{ 2 } } \\ Weight=29\quad N\quad (N\quad stands\quad for\quad Newtons;\quad 1\quad N\quad =1\frac { kg*m }{ { s }^{ 2 } } )[/tex]
Mass is constant for an object no matter where the object is in the universe. However, weight decreases as you get further away from Earth. This is because g (which is gravitational acceleration) decreases as your altitude increases above sea level. Astronauts still have the same mass as they do on Earth but their weight substantially decreases.
The FPS system equivalent of a Newton is a pound-force or just a pound. You'll notice that I didn't do the calculations for the FPS system. This is because scientists use the metric system and doing calculations in the FPS system becomes needlessly confusing.
Mod note: following information has been added by request of the poster on 29 december
Edit: I've made a mistake.
While I was correct that g (which is gravitational acceleration) decreases as your altitude increases above sea level, it does not decrease by as much as I made it seem. Astronauts actually still experience 95% of the weight that they would experience at sea level.
Here is why an explanation why astronauts float if you're interested:
