By choosing a suitable value of x, sum the series
  • Thread starter Thread starter bubokribuck
    Series Sum Value
The discussion revolves around summing a series involving alternating signs and odd natural numbers in the numerators, with a focus on understanding the relationship between the numerators and denominators. Participants are exploring how to express the series in a general form and are seeking clarification on specific components of the problem.
  • Participants are attempting to identify patterns in the series, particularly the relationship between the numerators and denominators. Questions are raised about the nature of the terms and the significance of the alternating signs. Some participants suggest calculating initial terms to gain insights.
The discussion is active, with participants sharing observations and asking for further clarification. Some guidance has been provided regarding the relationships within the series, and there is an ongoing exploration of how earlier parts of the problem relate to the current question.
There is mention of previous parts of the problem that may provide necessary context for solving the current question, specifically relating to a Fourier series representation. Participants express uncertainty about how these earlier components connect to the series they are currently analyzing.
bubokribuck
The question:
Here's my thought so far:
This is pretty much what I have come up with. However, I don't know how to find a general solution for the sum of the series. Can someone help please. (the decimal part is where I'm stuck the most)
bubokribuck said:
The question:
[itex]\displaystyle\frac{1}{1\cdot3}-\frac{3}{5\cdot7}+\frac{5}{9\cdot11}-\frac{7}{13\cdot15}+\dots[/itex]
What do we see?
The signs of the terms alternate.
Each successive numerator is the next odd natural number. If n is the index and starts at 0, then each numerator is (2n-1).
How are the two factors in each denominator related to each numerator ? (Consider what 2 times the numerator is for each.)
My guess is that those are not decimal points - they are multiplication dots.
Presumably you have noticed the alternating signs on the terms.
There is a simple relationship between the numerator and the two terms in the denominator in each term which will probably help.
What do we see?
Um... to be honest, I can't see how each denominator relates to each numerator, doesn't seem like there's a sequence. :confused:
Yes I have noticed the alternating signs, but couldn't find any relationship between the numerator and the denominator though :(
Well, calculate out the first ten terms, then come back and post them all.
[itex]+\frac{1}{1\times3}[/itex]
[itex]-\frac{3}{5\times7}[/itex]
[itex]+\frac{5}{9\times11}[/itex]
[itex]-\frac{7}{13\times15}[/itex]
[itex]\ldots[/itex]
You might also put in the known values for a, b and c (1,1,3) in your formula for [itex]n_{m}[/itex] and simplify.
Compare the factors in each denominator to 2 times the numerator !
Just a small typo--I'm guess you meant the numerator is 2n+1.
bubokribuck: What is the first part of this problem (that you've cut off from the image you posted)? The statement of the problem ("By choosing a suitable value of x...") indicates that in previous parts of this problem you've found a series representation for some function, which you are supposed to use to solve this part.
Hi spamiam, here's the full question, but I don't like it has anything to do with the previous parts though.
[itex]\ldots[/itex]
Hi Joffan, here it is.
If the first term is n=1, then the numerator of the first term would be 2n-1 right? (as 2(1)-1=1)
Ah, I think I am getting it now!
Let N denotes the numerator, and D denotes the denominator, then D=(2N-1)(2N+1). Is this right? So for the nth term, it would be something like (-1)n+1[itex]\frac{2n-1}{(4n-3)(4n-1)}[/itex]
It definitely has to do with the previous part! What could you be choosing x for if not to plug into the Fourier series you found in an earlier part? So what did you get for the first 2 parts? In particular, what did you get for the Fourier series of the function?
You formula for the general term of the series looks correct.
If the index, n, starts at zero, (like I said), then, yes, that should be (2n+1).
Hi spamiam, here's what I've got for the Fourier series:
And here's the sigma equation I've come up with for the last part of the question.
Hm, that's not what I get for the Fourier series. Could you show your calculations? Also, your series has a couple of oddities. For one thing, when n=1, you have terms of the form 1/0. Hopefully this doesn't pose a problem since these terms should cancel out. Which brings me to the second observation--you can simplify your sum since terms cancel out when n is odd.
Hi, the calculations are quite long, so I've attached a document. :)
Hey bubokribuck,
I (and I'm guessing this is the case with most other members from the 0 views your attachment has gotten) am wary of downloading zip files as a general rule. Could you upload it in another format like .doc, .pdf, or .jpg?
spamiam said:
Hey bubokribuck,
Hi, the doc exceeds the upload size limit, therefore I can only upload png. Thanks :)
Much better. I think your work is correct. I solved the integral differently, using to applications of integration by parts. As I said before, you really need to simplify your answer. I think you have a correct expression, but you need to combine your terms and put them over a common denominator.
The earlier parts of the problem are supposed to help later on! They can really save you a lot of work. For instance, I knew by inspection that all the [itex]a_n[/itex] were 0 just by observing that f is an odd function. Similarly, you can simplify the calculation of the [itex]b_n[/itex] by noting that the integrand is even.
So try simplifying your answer. Look for cancellation in terms of the form [itex](-1)^k + 1[/itex], too. I think this will make the choice for x a lot easier.
Hi spamiam, I don't seem to be able to cancel out the terms, is there something I've done wrong?
Looks good! The only tiny mistake I see is that you've forgotten the factor of [itex]1/\pi[/itex] during the course of your calculation. One other thing you might want to do is pull out a factor of -1 from [itex](-1)^{n+1} - 1[/itex].
Now write out the series for f again using your simplified version of the bn. This is where the cancellation comes into play. What is the value of bn if n is odd? How does this eliminate terms from the sum?
Hum... I'm not quite sure how to do that, the furthest I can go is:
= [itex](-1)^n(-1)^1 - 1[/itex]
= [itex]-(-1)^n - 1[/itex]
But the problem is when n=1, the denominator is still equal to zero (which is obviously wrong).
It doesn't really matter, but it's just [itex](-1)^{n+1} - 1 = (-1)(-1)^n + (-1)1 = -((-1)^n +1)[/itex]. You can stick that negative in the denominator if you like.
Yes, this is somewhat strange, but I think it's okay, because if n=1, then the numerator is zero, too.
So, as I said before, write out the Fourier series again and look for cancellation when n is odd or even.
10K
  • · Replies 0 ·
