C++ array with variable no. of elements?
8 replies · 8K views · last reply
Whovian
Code:
#include <iostream>
using namespace std;
int a;
int main()
	cin >> a;
	int c [a];
	for (int i = 1;i!=a+1;i++)
		c [i] = i;
		cout << c [i] << endl;
	return 0;
This compiles and does exactly what it's supposed to. But wait, I thought you could only declare arrays with a constant number of elements?
Aren't you declaring an array of length "a", where "a" has been initialized via input? (I'm not a C++ programmer, so I don't know if this is what you're asking about).
That feature is part of C99. Some compilers will also allow you to use this feature in C++.
However, I highly doubt this feature made it into C++11, since it would play havoc with C++'s type system.P.S. why is a global? P.P.S. your program has undefined behavior. In C/C++, arrays use 0-up indexing, so a 10-long array has indices 0 through 9. You are attempting to read/write to array index 10, which permits Bad Things to happen.
Sorry, a being global was a so-called "vestigial organ." Dunno, it seemed to work fine, but I took your advice and rewrote it to go 0 - a-1 instead of 1 - a. This also worked fine.
The standard way to get the effect of a variable-length array in C++ is to use a vector. Adapting your example and fixing the indexing bounds:
Code:
#include <iostream>
#include <vector>
int main()
    int a;
    cout << "Enter the size of the vector: ";
    cin >> a;
    vector<int> c(a);
    for (int i = 0; i < a; i++)
        c[i] = i;
        cout << "c[" << i << "] = " << c[i] << endl;
    return 0;
You're right. This concept is not a part of C++, past, present, or future. There's no reason for it; std::vector works quite nicely.
Yep use a vector, easy peasy.
You could also dynamically allocate more/less memory for an array - forgive my lack of C++ experience but in C you could use malloc()/realloc().
you can dynamically allocate an array from a pointer like this:
Code:
int *a;
a = new int [1024];  //allocate
delete [] a;             //deallocate
or even,
Code:
int **a;
a=new int * [1024];
for ( int i=0; i < 1024; ++i)
    a= new int [1024];
for (int i=0; i < 1024; ++i)
   delete [] a;
delete [] *a;
But, vectors are favorable to dynamic arrays in c++ according to all of the advice I have received.
Code:
#include <vector>
vectory <int> x;
    x.push_back(0);              //create a vector of 1024 items each equal to zero.
x[100]=24;                        //set value for one of the items in the vector
for (int i=0; i<1024; ++i)
   x.pop_back();                  //remove all of the items in the vector
jreelawg said:
Code:
vector <int> x;
It's quicker to do it this way:
Code:
vector<int> x(1024, 0);
Where push_back() really shines is when you're reading data and don't know in advance how much there will be:
Code:
vector<int> x;  // zero size initially
int num;
cout << "Gimme some numbers, terminate with ^D: ";
while (cin << num)
    x.push_back(num);  // x "grows" as necessary to accommodate the input
cout << "You entered: ";
for (int k = 0; k < x.size(); k++)
    cout << x[k] << " ";
cout << endl;
Or if you have a compiler that supports C++11:
Code:
for (int xnum : x)  // "ranged for-loop"
    cout << xnum << " ";
cout << endl;
