C/C++ [C++?] Counting the maximum number of equal objects in a vector
The discussion centers on efficiently tracking the maximum count of equal objects in a vector as they are added. One suggested method involves using a hashmap or dictionary, where each time an object is added, its count is updated. This approach is favored for its efficiency compared to continuous sorting, which could lead to O(n^2) complexity. An alternative method proposed involves using the object's value as an index in a large array, although this could require significant memory and initialization time. Concerns were raised about the feasibility of converting objects to long integers for indexing, with the consensus that while this could add overhead, a hashmap is more space-efficient and handles collisions better. Additionally, the use of assembly code for fast searches in an array was mentioned as a potential optimization.
burritoloco
Hi, say I have a vector that is currently being populated with some objects. I would like, as each object is added to the vector, to count the maximum number of equal objects currently in the vector. Would you know of any efficient algorithm that does this? Thank you.
Technology news on Phys.org
I'm guessing that perhaps continuous sorting (after defining a comparison relation on the objects) as the objects are added, and then counting the equalities could be a way to do this. Probably would take about O(n^2) at worst (n is the total number of objects to be added). Is there another way?
Use a hashmap\dictionary. As you add the item to the vector check the dictionary and if the item exists increment the value otherwise add it with a value of 1.
As an alternative to a hash algorithm, depending on the number of bits in each object, you could use the object's value as an index into a very large array, and increment the array for each object. The overhead would be the time it takes to zero out the array to initialize it, and when done, to scan the array for non-zero values.
Thanks guys. The hashmap idea looks straightforward. rcgldr, I can define a function to convert these objects into longs (to be used as indices of an array as you suggested), but this would additional time, no? Is there a native c++ way to do this conversion? (the usual type casting doesn't work here).
burritoloco said:
The hashmap idea looks straightforward. rcgldr, I can define a function to convert these objects into longs (to be used as indices of an array as you suggested), but this would additional time?
Yes, and assuming you mean 32 bit longs, it would take too much memory, the array size would be 4 billion elements. Using values as indexes is a software alternative to a content addressable (also called associative) memory. A hashmap does the same thing but uses much less space (assuming only a small sub-set of possible values are used). The hash table will have "collisions", and generally you'd want the hash table to end up about 1/2 empty to reduce collision overhead.
You could use assembly code to do a fast search of an array for a value, using repne scas... for 8 (scasb), 16 (scasw), 32 (scasd), or 64 (scasq) bit values, either inline or as a separate module.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 41 ·
  • · Replies 25 ·
