Comp Sci How can I dynamically name files in C++ using a string and integer?
  • Thread starter Thread starter burritoloco
    Dynamic File
To dynamically name files in C++, concatenate a string with an integer using the `std::to_string` function or `sprintf`. The example provided shows how to create a filename by appending an integer to a string. Using `std::ofstream`, the file can be opened with the constructed filename. The approach is confirmed to work effectively in C++. This method is a valid way to handle file naming in C++.
burritoloco
Hello,
I'm wondering how to name/open a file whose name is given by a string with an integer appended at the end, i.e., something in the style of the following. Thank you!
int i = 5;
ofstream fout;
string s = "Hello " + i;
fout.open(s);
// write something to the file
fout.close();
I would take
Code:
char filename[32];
sprintf(filename,"name%i",i);
fout.open(filename);
route, but I am not convinced it is how it should be done in C++. I started with C and have tendency to code in C+.
Thank you. Worked perfectly.
  • · Replies 16 ·
