C-parity π+ π- π0: Is (-1)^L (+1) Correct?
The C-parity of the π+ π- π0 system is determined to be C = +1, calculated as (-1)(-1)^(L), where L represents the angular momentum quantum number of the π+ π- subsystem. This indicates that the two-pion and three-pion systems exhibit opposite CP eigenvalues, providing evidence for CP violation through the observation of K_{0 L} decays. The C eigenvalue is multiplicative, allowing for the calculation of the total CP eigenvalue using the formula C(pion)^n P(pion)^n (-1)^L. To ascertain the C and P eigenvalues of single particles like pions, one must reference established values from basic particles such as protons and electrons.
  • Understanding of C-parity and CP violation in particle physics
  • Familiarity with angular momentum quantum numbers
  • Knowledge of basic particles and their quantum numbers (e.g., protons, electrons)
  • Experience with particle decay processes and their implications
  • Study the implications of CP violation in K_{0 L} decays
  • Research the calculation methods for C and P eigenvalues in multi-particle systems
  • Learn about the role of angular momentum in particle interactions
  • Explore experimental techniques for measuring C and P quantum numbers in pions
Particle physicists, researchers studying CP violation, and students of quantum mechanics will benefit from this discussion, particularly those focused on the properties of mesons and their decay processes.
ln(
TL;DR
C-parity of π+ π- π0 compared to π+ π-
The C-parity of π+ π- alone is simply (-1)^L, where L is the angular momentum quantum number for the system. But then what is C-parity of π+ π- π0? Is it simply (-1)^L (+1), where L is the angular momentum quantum number for the π+ π- subsystem (which isn't necessarily the angular momentum of the whole three pion system)?
π+ π- π0's CP is(-1)(-1)^(L). So, two pions and three pions have opposite CP eigenvalues. Therefore, observation of both K_{0 L} to two pions and three pions decays is clue of CP violation.
This implies C = +1 which seems right. But how do you calculate C eigenvalue directly?
C is multiplicative quantum number. So, once you know C of a single pion, you just need to perform C^n for n pions system. It is same for P. So, C(pion)^n P(pion)^n (-1)^L is total CP eigenvalue.
If you ask how we can know C or P eigenvalue of single particle such as pion, I would answer that we need to set C and P eigenvalues to several basic particles such as proton and electron. Then, we can study C and P quantum number of other particles (i.e. pions) using physical process such as pion + deutron to two neutrons.
