C program could not be compiled and executed at Windows command prompt
14 replies · 4K views · last reply
WMDhamnekar
MHB
TL;DR
I have downloaded and installed ' C c-programs application from Microsoft Windows store. I copied one program named 'Days Convertion' from it to my Notepad++ and saved it as c source file in the Documents folder. When I tried to compile it using gcc, gcc said No such file or directory. How can I fix this error?
When I tried to run this c program in online IDE, it showed several compiling errors. https://ide.geeksforgeeks.org/?ref=ndm
C:
/*    Write a c program to convert given number of days to a measure of time  *    given in years, weeks and days. For example 375 days is equal to 1 year  *    1 week and 3 days (ignore leap year)  */
 #include stdio.h #define DAYSINWEEK 7
 void main() {    int ndays, year, week, days;
    printf("Enter the number of days\n");    scanf("%d",&ndays);
    year = ndays/365;    week = (ndays % 365)/DAYSINWEEK;    days = (ndays%365) % DAYSINWEEK;
    printf ("%d is equivalent to %d years, %d weeks and %d days\n",           ndays, year, week, days); }
When I tried to compile it using gcc at windows command prompt, I got the following error several times. After giving this command at command prompt, 'DaysConvertion.c' file disappeared from the Documents folder.
Windows Command Prompt showing repeated gcc errors: 'cannot find DaysConvertion' with 'No such file or directory' and 'collect2.exe: error: ld returned 1 exit status'.
Are you sure you are in the right Documents folder? At the command prompt, what do you get when you type dir *.c ?
Yes. I am in appropriate documents folder. In user variables, I set the PATH for gcc downloaded from https://winlibs.com/#usage-commandprompt. C: \mingw W64\bin.
The file names are the wrong way round in the command: you are telling gcc to compile the source file DaysConvertion (which doesn't exist) to produce the object file DaysConvertion.c.
Just type gcc DaysConvertion.c and see what happens.
By the way "convertion" is spelled "conversion" in English.
Thanks for finding out my and author's spelling mistake (author means author of 'C c-programs ' application from Microsoft windows store).
After gcc compiling command at command prompt, the file was no more in the documents folder.
The result of your suggestion is as follows:
Windows Command Prompt window showing dir *.c reporting File Not Found in C:\Users\Winod\Documents, then gcc DaysConvertion.c failing with cc1.exe fatal error: No such file or directory and compilation terminated.
My advise to you is Just run this program in the online IDE given by me , you will see plenty of errors in the program
Well, what happens if you put it back?
When I do these steps several times using Notepad++, I repeatedly get the same error at the command prompt.
Can you post the result of the dir *.c and the compile command using a screenshot of the DOS Box?
After I fixed one syntax error, I was able to get the program to run in the online IDE.
This line - #include stdio.h
should be written as #include <stdio.h>
When I ran that code, I entered 300, and the program reported "300 is equivalent to 0 years, 42 weeks and 6 days".
I don't use gcc, so can't give you any help on that compiler, other than to suggest that you don't have things set up correctly.
Your earlier command in post #1 told gcc to overwrite your .c file with the compiler output. That might have wiped out your code .c file. The dir command in your post #5 says that the file doesn't exist, so what did you expect gcc to do?
I suggest that you start over and put your code in the DaysConvertion.c file. This time use the simple command "gcc DaysConvertion.c" and see what happens.
Would you tell me which online IDE did you use successfully?
My use of online IDE gave me the following result:
Screenshot of the GeeksforGeeks online IDE showing a C program editor with a comment block reading 'Write a c program to convert given number of days to a measure of time given in years, weeks and days' and a #include <stdio.h> line.
Screenshot of an online C compiler showing code lines 22 to 26 with 'void main()' and an opening brace, a program output of 300, Run and Run+URL buttons, and compile errors about stray characters before '#include <stdio.h>'.
See all those characters highlighted in red? Why do you think they are highlighted in red?
I don't know the meaning of …, .., . in red colour in the program I put in the online IDE. In my opinion, these red dots represents errors. But how to debug this program is my problem. Do you know it's solution? :confused::sorry:
You could try deleting the errors (were they there in the code you copied or do you think they have appeared as part of the copying and pasting process?)
Also note that the Notepad doesn't work well with text copied from a web page, use a proper text editor designed for code like Visual Studio Code.
These errors were appeared as a part of copying and pasting process.
Windows Command Prompt window showing DaysConversion.exe run, with input 3450 and output '3450 is equivalent to 9 years, 23 weeks and 4 days'.
This question is solved.:biggrin::smile::oldlaugh:
