C++ Program Help: Calculate Average Weight & Height by Age & Gender
  • Context: Comp Sci
  • Thread starter Thread starter essdb1
    C++ Program
1 reply · 4K views
essdb1
//Sherman Brown
//CIS 150-01 Programming in C/C++
//April 17, 2011
//Program #7
//Organizing data by age and gender, calculating average weight/height.
//Preprocess Directives
#include <iostream>
#include <iomanip>
#include <fstream>
//Namespace used
using namespace std;
//global variables
int age;
int count1;
int count2;
int count3;
int count4;
int count5;
int count6;
int minoravgheightF;
int minoravgweightF;
int minoravgheightM;
int minoravgweightM;
int adultavgheightF;
int adultavgweightF;
int adultavgheightM;
int adultavgweightM;
int oldavgheightF;
int oldavgweightF;
int oldavgheightM;
int oldavgweightM;
char gender;
double height;
double weight;
void avgfunc(int minoravgheightF,int minoravgweightF,int adultavgheightF,int adultavgweightF,int oldavgheightF,int oldavgweightF,int minoravgheightM,int minoravgweightM,int adultavgheightM,int adultavgweightM,int oldavgheightM,int oldavgweightM);
void printavg();
//main function/value returning function
int main()
ifstream inputfile; //input stream variable
ofstream outputfile; //output stream variable
inputfile.open("Prog7Input.txt"); //opens file
if (!inputfile) //if...else ensures file opens correctly
count << "File not found." << endl;
count << "Ending now." << endl;
else
inputfile >> gender >> age >> height >> weight; //gets first line of input from file
while (!inputfile.eof()) //necessary .eof like stated in assignment
void avgfunc();
void printavg();
return 0;
void avgfunc() //void function that reads and processes
if ((gender == 'f') || (gender == 'F'))
if ((age >= 0) && (age <=18), count1++)
minoravgheightF = minoravgheightF + height;
minoravgweightF = minoravgweightF + weight;
else if ((age >= 19) && (age <=35), count2++)
adultavgheightF = adultavgheightF + height;
adultavgweightF = adultavgweightF + weight;
else if (age >=36, count3++)
oldavgheightF = oldavgheightF + height;
oldavgweightF = oldavgweightF + weight;
else
count << "Unanalyzable data." << endl;
else if ((gender == 'm') || (gender == 'M'))
if ((age >= 0) && (age <=18), count4++)
minoravgheightM = minoravgheightM + height;
minoravgweightM = minoravgweightM + weight;
else if ((age >= 19) && (age <=35), count5++)
adultavgheightM = adultavgheightM + height;
adultavgweightM = adultavgweightM + weight;
else if (age >=36, count6++)
oldavgheightM = oldavgheightM + height;
oldavgweightM = oldavgweightM + weight;
else
void printavg() //void function that print to outfile
outputfile << "Age Range: Male Height: Male weight: Female Height: Female Weight:" << endl;
outputfile << fixed << showpoint << setprecision(1);
outputfile << setw(6) << "0-18" << setw(13)
<< minoravgheightM / count1 << setw(13)
<< minoravgweightM / count1 << setw(13)
<< minoravgheightF / count2 << setw(13)
<< minoravgweightF / count2 << endl;
outputfile << setw(6) << "19-35" << setw(13)
<< adultavgheightM / count3 << setw(13)
<< adultavgweightM / count3 << setw(13)
<< adultavgheightF / count4 << setw(13)
<< adultavgweightF / count4 << endl;
outputfile << setw(6) << "36+" << setw(13)
<< oldavgheightM / count5 << setw(13)
<< oldavgweightM / count5 << setw(13)
<< oldavgheightF / count6 << setw(13)
<< oldavgweightF / count6 << endl;
One, I have no clue how to fix this. Yes it is an assignment as I clearly left that viewable, I just need a little help.
And showing me how to make this code easily viewable on this site would be useful!
on Phys.org
What you want to do is enclose your code in code tags. Put [ CODE] in front and [ /CODE] at the end, removing the space I put after the opening square bracket. And thanks for caring about that! :)
Code:
//Sherman Brown
//April 17, 2011
//Program #7
#include <iostream>
#include <iomanip>
#include <fstream>
//Namespace used
//global variables
int age;
int count1;
int count2;
int count3;
int count4;
int count5;
int count6;
int oldavgheightF;
int oldavgweightF;
int oldavgheightM;
int oldavgweightM;
char gender;
double height;
double weight;void avgfunc(int minoravgheightF,int minoravgweightF,int adultavgheightF,int adultavgweightF,int oldavgheightF,int oldavgweightF,int minoravgheightM,int minoravgweightM,int adultavgheightM,int adultavgweightM,int oldavgheightM,int oldavgweightM);
void printavg();
int main()
		cout << "File not found." << endl;
		cout << "Ending now." << endl;
	else
		void avgfunc();
void printavg();	return 0;
			else
				cout << "Unanalyzable data." << endl;
	else
Some of the problems that jump out at me are:
1. A massive list of global variables. Avoid global variables unless you truly need them (and that should happen from almost never to never).
2. That parameter list in the avgfunc() function is crazy long. You could put them into a structure and pass the structure to any function that needs all those parameters. Or perhaps they can be organized differently. For example, you could have the function only need avgHeight and avgWeight (plus any other important stuff I'm missing), and call it for each case (minor/male, minor/female) etc. In any case, that data can almost certainly be better organized.
3. The declaration of avgfunc() has a ton of parameters, but the definition does not. The parameter lists must match.
4. This is c++, so perhaps this should be a class?
A close look at your main is needed, as well. This is the part I mean:
Code:
	else
		void avgfunc();
After checking to make sure the file opened correctly, you should use this kind of thing to loop until it hits EOF:
Code:
while (inputfile >> gender >> age >> height >> weight)
    // Process line
You shouldn't have to read a line in before going into the while loop, nor check for EOF explicitly.
You also appear to be trying to call avgfunc wrong (same with printavg). It's not:
void avgfunc();
Ignoring the fact that you declared it to need a big list of parameters, which are missing, that void is wrong. It should be just:
avgfunc(...parameters go here...);
Lastly, since this is homework help, note it says not to post homework here in the stickied posts. The proper forum for that is:
Science Education > Homework & Coursework Questions > Engineering, Comp Sci, & Technology
Don't worry, we check that one too. Wish it wasn't mixed in with engineering and such, but what can you do.
That's what I see after a quick pass through, anyways. Hope that helps!
EDIT: Missed one thing. When you detect that there was a problem opening the file, you say "Ending now.", but you don't. Pretty much all the code for when it does open correctly should be in the else block.
ANOTHER EDIT: He asked you to call .eof() in the assignment? Ouch. You should read these short pages:
http://www.fredosaurus.com/notes-cpp/io/cinloop.html
http://www.fredosaurus.com/notes-cpp/io/anti-idiom-cin.html
