C program to open a file
anbhu28
can anyone help me me? need a c program to open a file using c
pls can anyone send me a c programing code for opening a files
The simplest way to open a file is "fopen(Filename, mode)" where Filename is the file name as a string and mode is string such as "r" for "read only", "w" for "write", "a" for "append" (add to end of file), and a number of others.
That returns a pointer to the open file that you would then use in reading or writing to the file.
For example,
FILE *f= fopen("myFile","r");
makes f a pointer that can be used to read from "myFile".
You could then use "fread(buffer, 10,10, f)" to read up to 10 bytes from the file to the variable "buffer" (which you would declare as a pointer to the correct type of variable) or you could use fscanf(f, ...) to read a formatted string just as you would with "scanf".
