speny83
- 17
- 0
A sample of carbon dioxide, mass 2.45g, is allowed to expand reversible & adiabaticly from 500cm3 to 3.00 dm3
What is the work done by the gas
dw=-pexdV
du=dq+dw
du=nCv,mdt
At first i just wanted to say that because dw=-pexdV and pex=p=[itex]\frac{nrt}{v}[/itex] so w=-nrt∫dV/V...w=-nrt*ln(vf/vi)
however this doesent give me the correct sollution, but i don't understand why i can't say that.
my second thought was to say that because du=dq+dw and dq=0 for adiabatics that it would make du=dw and with du=nCv,mdt so w=nCv,mΔT i could go about it this way, but i need to find the final temp, as an aside: is the reason i cannot use charles law here because work is being done so p is not constant?
ok so i need final T which i can get by Tf=([itex]\frac{Vf}{Vi}[/itex])1/c
my notes say that c=Cvm/R and, this is not part of the notes, Cvm for CO2 (because its linear) is just 5R/2 right?
however the solution guide goes into all this c=[itex]\frac{Cvm}{R}[/itex]=[itex]\frac{Cpm-R}{R}[/itex]=3.463
but they don't explain any numbers...if you try to reverse calc it (3.463*8.3145)+8.3145 you get 37 somethig which doesent coordinate to anything either...also wouldn't Cp,m just be 7R/2?
now I am so confused i don't know what to do
I moved on and worked some other problems (involving CO2) where i had to find [itex]\gamma[/itex] being Cpm/Cvm doing this using Cpm=7R/2 and Cvm=5R/2 worked just fine so I am inclined to believe that the above just doesent make a lick of sense
