Calc 3 questions concerning Normal and Tangent unit Vectors
5 replies · 6K views
badtwistoffate
heres is one problem i did, i photo'd it so i wouldn't have to worry about it...
Am I doing it right? any problems can you see :-/ on like the 8th/9th line, I don't think I can do what I did...
http://img130.imageshack.us/img130/1332/test076ze.jpg
Sooo
Since you have
[tex]\vec{T} (t) = \frac{1}{\sqrt{5t^2+1}} \left< 1,t,2t\right>= \left< \frac{1}{\sqrt{5t^2+1}},\frac{t}{\sqrt{5t^2+1}},\frac{2t}{\sqrt{5t^2+1}}\right>[/tex]
[tex]\vec{T} ^{\mbox{ }\prime} (t)[/tex] will require the quotient rule, the result is
[tex]\vec{T} ^{\mbox{ }\prime} (t) = \frac{1}{(5t^2+1)\sqrt{5t^2+1}}\left< -5t,1,2\right> = \frac{1}{(5t^2+1)^{\frac{3}{2}}}\left< -5t,1,2\right>[/tex]
So I do the quotient rule to each of the components of T(t)?
How did you get your answer for T'(t)?
Instead of the quotient rule, I think I would be inclined to write the components as
[tex](5t^2+1)^{-\frac{1}{2}}[/tex]
[tex]t(5t^2+1)^{-\frac{1}{2}}[/tex]
[tex]2t(5t^2+1)^{-\frac{1}{2}}[/tex]
and use the product and chain rules.
Why not just differentiate the un-normalised tangent vector then normalise it afterwards? Seems computationally simpler to me.
Edit: Hm, doesn't work. I don't understand why differentiating a normalised tangent vector vs. a tangent vector should change the direction in which the resulting vector points. I also don't understand why the derivative of the normalised tangent vector will always be normal, seems to me that would be an acceleration and should therefore only be normal if the particle isn't picking up any kinetic energy.
Guess I'm going to have to break out my calculus book and do some reading :wink:
