Calc height of cone with only volume and angle
To calculate the height of a cone with a volume of 2.0 m³ and a top vertex angle of 60 degrees, the volume formula V = 1/3 * π * r² * h is used. By dividing the cone's cross-section into right triangles, relationships between the radius (r) and height (h) can be established using trigonometric functions. The calculations yield a radius of approximately 1.03 m and a height of about 1.79 m, which satisfy the volume equation when checked. An alternative method confirms the same height by relating r and h through geometric principles. The calculations are verified as correct, providing a solid solution to the problem.
rustys111
hi all,
Ive been sitting up so late trying to work something out.
If anyone could help that would be great.
How do i calculate the height of a cone if the internal angle of the cone at the top vertex is 60degrees and the total volume for the cone is 2.0m3?
this is just a example - if you could guide me in the correct path and give me a quick awser so i can check my workings that would be great.
Thanks all
What are the formulae for volume of a cone? (Forum rule: no help without you showing your working - you say you have some, so what have you done?)
No worries
Given V = 2 internal angle at vertex = 60
volume = 1/3*Pi*r^2*h
Draw cone cross section - dive into two triangles to make a right angled tri
Angles in tri = 90, 60 & 30
S = hyp of right angled tri
therefore
using Angle 60
r = Scos60
h = Ssin60
v = 1/3 * Pi*r^2*h
2 = 1/3 * Pi * (Scos60)^2 * (Ssin60)
(2*3)/pi = (Scos60)^2 * (Ssin60)
Sqr((2*3)/pi) = Scos60 * Sqr(S) * Sqr(Sin60)
(Sqr((2*3)/pi) / sqr(sin60) = Scos60 * Sqr(S)
((Sqr((2*3)/pi) / sqr(sin60)) /cos60 = S * Sqr(S)
(((Sqr((2*3)/pi) / sqr(sin60)) /cos60) ^2 = S^2 * S
(((Sqr((2*3)/pi) / sqr(sin60)) /cos60) ^2 = S^3
((((Sqr((2*3)/pi) / sqr(sin60)) /cos60) ^2) ^ 1/3 = S
solve for S = 2.0662216704972 (Accuracy required)
input back in
r = Scos60
h = Ssin60
Radius (r)= 1.03311083738979
Height (h)= 1.78940045526428
Check
Place back into equation for volume
V = 1/3*Pi*r^2 *h
V = 2
Am i correct?
Thats what i need to know
Is there any other way about this??
rustys111 said:
No worries
therefore
using Angle 60
r = Scos60
h = Ssin60
You should state which angle is 60! Dividing the cross section into two right triangles, you have angles of 60 and 30 degrees. I normally think about the vertex angle but you are using a base angle- that confused me for a moment!
Another way to do this is to recognize that since 60 degrees gives an equilateral triangle, dividing into two triangles gives a right triangle with hypotenuse of length S and one leg of length S/2 (the radius of the cone). By the pythagorean theorem, S^2= h^2+ S^2/4 so h^2= (3/4)S^2 and h= (\sqrt{3}/2)S.
Since r= S/2 and h= (\sqrt{3}/2)S, dividing the first equation by the second, we have r= h/\sqrt{3}
v = 1/3 * Pi*r^2*h
input back in
r = Scos60
h = Ssin60
Check
V = 1/3*Pi*r^2 *h
V = 2
Am i correct?
As above r= (1/\sqrt{3})h.
V= (1/3)\pi r^2 h= (1/3)\pi (1/3)h^3= \pi/9 h^3= 2
h^3= 18/\pi= 5.73
h= 1.79[/tex]<br /> Just what you have.
  • · Replies 17 ·
9K
10K
