Calculate elasticity of rubber balloon
The discussion revolves around modeling the respiratory system of a neonate using a rubber balloon to simulate pressure/volume relationships in the lungs. Participants explore the challenges of calculating elasticity, the non-linear behavior of rubber, and the appropriateness of using a balloon as a model compared to other mechanical systems.
  • One participant proposes using a rubber balloon for modeling lung behavior, assuming it behaves linearly and is perfectly spherical.
  • Another participant points out that the elasticity equation E = σ/ε requires the pressure to be the difference between inside and outside pressure.
  • A participant challenges the proportionality of volume and pressure, suggesting that a balloon may not accurately represent lung behavior since the volume does not go to zero when pressure difference is zero.
  • Concerns are raised about the linearity of volumetric expansion in balloons over large ranges and the effect of membrane thickness on elasticity.
  • One participant suggests that a piston and cylinder model might provide a better representation of lung mechanics than a balloon.
  • Another participant emphasizes the need for a nonlinear mathematical relationship to model the elasticity of rubber, noting that the elasticity is a material property that may depend on strain.
  • Participants discuss the specific context of surgeries where CO2 is inflated in the thorax or abdomen, affecting lung and diaphragm behavior, and the need for a model to study these interactions.
Participants express differing views on the suitability of a rubber balloon as a model for lung mechanics, with some suggesting alternative models like a piston and cylinder. There is no consensus on the best approach or the accuracy of the assumptions made regarding the balloon's behavior.
Participants note limitations regarding the assumptions of linearity and the complexity of the pressure-volume relationships in biological systems. The discussion highlights the challenges of modeling non-linear behaviors and the dependence on specific material properties of rubber.
This discussion may be of interest to biomedical engineers, researchers in respiratory mechanics, and those involved in surgical modeling and simulation.
AlexMentink
Dear readers,
For a Biomedical Engineering project I have to develop a model for the respiratory system of a neonate. This will be done by using pressure/volume data of the lungs. To model these, I would like to use a rubber balloon. However the calculation are more difficult than I thought.. (Especially because rubber behaves non-linear and with a hysteresis effect, I will ignore these effects) As assumptions I used the fact that the balloon is perfectly spherical, behaves linearly and the strain is dependent on the radius relative to the original radius (R0).
Could anyone help me?
Thanks!
Well, for one thing, E = σ/ε. And, you are aware the p in your equation is the inside pressure minus the outside pressure, correct?
Chet
Ah of course, thanks for noticing..
Yes the p should be the difference in pressure. Should the formula be correct now?
The relation in red does not follow from your calculations.
You don't have proportionality with V^(-1/3).
By the way, E and p have the same dimensions and can be measured in the same units (Pa or N/m^2).
What is t? The thickness of the membrane?
Hmm ok, the thing is I have a linear relationship between the lung volume and pressure, therefore I would like to use V/p or p/V in the equation to solve for E.
I don't have any idea how to extract p/V or V/p from this relation..
t is indeed the thickness of the membrane
You could call that ratio "x" and express p as x*V in the equation.
Then solve for this x.
Or just solve for p and then divide the result by V. It will depend on volume as well as the parameters of the balloon.
The relationship may be linear, but it is not a direct proportion (at least not in the case of your lungs). When the pressure difference goes to zero, your lung volume does not go to zero. In the case of a balloon, when the pressure difference goes to zero, the volume of the balloon does go to zero. So maybe a balloon is not such a good quantitative model of a lung.
Chet
Volumetric expansion of a balloon with pressure can never be very linear over large ranges
Membrane thickness will reduce considerably for non trivial volumetric expansions .
Maybe something more like a cylinder and piston with a spring ?
Or a cylindrical bellows with a spring ?
The thing is that I'm building a box as a model for the respiratory system including diaphragm and abdomen stiffness. In most surgeries CO2 is inflated in either the thorax or abdomen to make room for using the instruments. The box should model the relationships between lungs, diaphragm and abdomen stiffness.
During all real procedures, a minimum pressure is inflated into the lungs, to make sure they don't stick together. Therefore in this model, the balloon will be kept at a minimal pressure and will have a minimal volume.
Finally, the lung pressure/volume relationship is not really linear, but in the form of y=ax^2-bx. The problem is that I don't know how to setup a nonlinear mathematical relationship using the material properties of a rubber balloon. Does anyone know what the general formula is for calculating the elasticity of rubber (non linear)?
The elasticity of rubber is given, it is a material property.
It may depend on the strain in the material (this will make the material non-linear).
What do you actually try to calculate the elasticity? Starting from what?
What are these p/v data for the lungs mentioned in the OP?
P/v versus what parameter?
Apart from looking a bit like a lung, how does a balloon provide a better model than a cylinder and piston? A piston could actually be driven with servos to give it all sorts of pv characteristics or a number of pistons in cylinders with springs could provide a mechanical model to any degree of agreement. the diaphragm is as much like a piston in structure as a balloon.
Thanks for all quick replies!
I will make it a bit more clear.
In most surgeries CO2 is inflated in either the thorax or abdomen to make room for using the instruments. In the case of a thorax surgery, a needle is placed between the lungs and ribcage inflating CO2 (causing a pneumothorax). Increase in pressure will squeeze the lungs together and the diaphragm down. Data about these pressure-volume relationships are known.
In the case of an abdominal surgery, a needle is placed between the intestines and CO2 is inflated. Increase in pressure will cause the diaphragm to go up and the abdominal wall expand. Data about these pressure-volume relationships are known as well.
The box should model the relationships between lungs, diaphragm and abdomen stiffness to research the effect of pressure in the thorax on the abdominal wall etc.
Professional inflators with adjustable flow/pressure/volume are available.
The box will be air-tight and easy to disassemble.
The box will look something like this. Open sides will be covered with a rubber membrane and pressed together to make the box air-tight. The openings on the sides are for CO2 inflation and measurement of pressure differences. The opening on top is for the respiratory inflation (model for the lungs will be placed here).
11K
  • · Replies 17 ·
