Calculate Initial Velocity of Object Thrown Vertically
The discussion revolves around calculating the initial velocity of an object thrown vertically that reaches a height of 30.0 m, with gravity considered as 9.81 m/s². Participants explore various approaches to determine the initial velocity without providing a direct solution.
  • Participants discuss using conservation of energy and kinematic equations to approach the problem. Some question whether the problem might be a trick question, while others suggest specific equations and methods for calculation.
The discussion is active, with participants offering different perspectives on how to approach the problem. Some have provided equations and concepts, while others are questioning assumptions and the relevance of mass in the calculations.
There is uncertainty regarding the mass of the object, which is not provided. Participants are also considering the implications of neglecting air resistance and the significance of specific points in the object's trajectory.
Brittykitty
An object is thrown vertically into the air and reaches a height of 30.0 m. Neglecting air friction, what was the object’s initial velocity?
What would the equation be for this question?
I know that:
Height: 30.0m
Gravity: 9.81m/s
I'm not quite sure what else I need to figure this out? thank! :)
Is this a trick question where its 0m/s?
The easiest way would be to use conservation of energy:
E = 1/2mv^2+mgh
Alternatively, you could use the equation of motion for the object. You know it has a constant acceleration g downwards.
Thank you! so would it look something like this:
E=1/2 (230kg)(0.02ms) ^2 + (230kg)(9.81m/s)(32m)
0.092 + 77201.6 = 77201 ?
oops i mean
5.43 + 72201.6 = 72207.03
The power behind conservation of energy is that you can use the equation for E at any point in the objects trajectory and you will always get the same answer.
You haven't been given the mass of the object, but the answer will be independent of the objects mass anyway.
You have two special points in the objects trajectory which are important to your question. Which are those and what is the expression for the energy at those points?
gravity, height and time?
I think using Vf^2=Vi^2 + 2ad would be better..Since the highest point is 30 that means at that point v equals 0.
  • · Replies 18 ·
