Calculate momentum and velocity of ball after collision
The discussion centers on calculating momentum and velocity after two collision scenarios involving balls. In the first problem, a ball moving west collides with a stationary ball, resulting in the first ball moving south, prompting questions about momentum conservation and vector components. The second problem involves a cue ball striking a nine ball, leading to discussions about momentum distribution in two dimensions. Participants emphasize the importance of breaking down momentum into horizontal and vertical components and using unit vector notation for clarity. The conversation reveals confusion over the physical plausibility of the scenarios presented, suggesting potential errors in the problem statements.
IGeekbot
HOw do I do these two problems. I know it has something to do with angles the ball trike each other, but I am so Lost.
Problem 1.
Ball A, rolling west at 3.0m/s, has a mass of 2.0 kg. Ball B is 2.0 kg,and is stationary. After colliding with ball b, ball a moves south at 2 m/s. calculate the momentum and velocity of ball B after the collision.
Problem 2.
A cue ball, moving with 7.0 Ns of momentum strikes the nine ball at rest. The nine ball moves off with 2.0Ms in the original direction of the cue ball and 2.0Ns perpendicual to that direction. What is the momentum of the cue ball after the collision.
I have no idea what to do with these.
Are you familiar with 2d collisions and the principles of conservation of momentum?
yes, i have my book here in front of me with equations, but I am not sure which one to use.
Well, consider using conservation of momentum for two dimensions (meaning that you break them up into x and y components)...
Show us what you are trying to do in equations, and we'll work from there :D
thats just it, i don't know what to do. Our teachers idea of introducing a new concept is go through it in five minutes to move on to a lab. He justrecites the book so it is no help. I know we have to use the sin and cos of one of the veloctiies, but i am not sure which one. When i get osm calculations going here, ill show ya
In your particular case, you don't have to. Are you familiar with unit vector notation to express vector quantities?
Let's just look at #1 for now.
By conservation of momentum, you know that the momentum in each directional component has to be equal before and after the collision. Right?
Now, what is the original momentum:
1. Of ball A in the x (east-west) component?
2. Of ball A in the y (north-south) component?
For simplicity purposes, let's just east as +x, and north as +y.
ive probably seen them, but that is not ringing a bell. could you please explain what it is?
The unit vector notation basically breaks down a vector quantity into its directional components (i, j, k) or (x, y, z), depending on what notation you like to use. This way, you can express a quantity say, 3 units to the east and 4 units to the north, as 3i + 4j, for instance. This quantity is the same as saying 5 units (~51 degrees north of east)... familiar?
The ball would have the original momentum of 3kg x m/s moving west. I got that, but this is where I get lost, because this is all new to me.
Ok. Why don't we start even further back. Can you type out the conservation of momentum equations at least? :-)
you mean 3.0m/s * 2.0kg = 6.0 kg*m/s...
To calculate momentum, it is P=mv.
In a closed system you have Pa+Pb=P'a+P'b
Then we have the ones for elastic and inelastic equations, but i don't think those are needed here.
yeah, wrong key.
and no, we have never done vectors like that. I think i will read on that more.
Now. Note that momentum is a vector quantity (because velocity is).
So, you can further break it down to:
Pa_x + Pb_x = P'a_x + P'b_x
Pa_y + Pb_y = P'a_y + P'b_y
Now, in your case, you know that
Pa_x = 6, and Pb_x = 0, and Pb_y = 0
You also know...
Pa'_y = 4
With units in kg*m/s
Do you see where I was getting my numbers?
Check the beginning of your book - almost all books have a section on that stuff at the very beginning - I suppose you are on the high school/intro college level?
so I need to use the horizontal and vertical numbers? Then, when you get those, they should equal the initial momentum of the ball, which is 6 kg*m/s?
Yeah, its an intro class, and the teacher expects you to pick it up the frist time, and if you ask for help, he still won't really explain it. He just repeats what he says. And I foudn that section, and we have just used it a little bit.
Yes, you need to break them down into the horizontal and vertical components. Whenever you work with more than one dimension, do that.
When we get those, the *individual* components should conserve.
And a slight correction on my notation earlier.
P_ax should be -6 and P'_ay should be -4, because I specified +x and +y to be east and north, respectively.
You actually also know that P'_ax is 0, because after the collision, the ball only moves south at 2m/s, so it's not traveling in the east-west direction at all. As a result, after the collision, ball a has a horizontal momentum of 0.
Doesn't sound like much of a teacher then. Welcome to PF, both of you :smile:.
Thanks bunches! Yeah, I remember having teachers like that. I guess one of the things I quickly learned was how to teach myself. It was the most important thing I learned over the years...
I really suggest you know your unit vectors really well, as I bet this stuff will help you in your future physics and mathematics courses.
ok, I think I am getting this. Ball B, it will have a velocity of -1 m/s, since it is moving east, and it has a mass of 2kg.
Because the original velocity is 6kg*m/s east when the ball makes contact, the two balls afterward will have to have a 6kg*m/s momentum. Since the angle is 90degrees, the hypotenuse of that triangle will be the 6kg*m/s. if you take the original momentum then, 6kg*m/s, and subtract the momentum of ball A after the collision, you will have the total momentum of Ball B. That is part of the answer, and if you divide that answer by the 2 kg, it will give you a velocity which will be 1.
I know that is garbled a bit, but am i on the right track?
And nylex, thanks for the welcome.
You know, hold on a minute for this one. What I *really* want to know, is how a ball that strikes a stationary ball with no vertical momentum develops vertical momentum. Ball A only had horizontal momentum, and Ball B orginally had no momentum. It should therefore even be impossible for Ball A or B to develop vertical momentum, unless there is some external force. Anyone want to take a stab at this, or am I just suffering from dementia?
Good point! I was kinda missing the point when you asked if IGeekbot knew about momentum in 2D, cos it just seemed like a 1D collisions problem to me.
Oh and IGeekbot, if it's easier, you can write the units of momentum as Ns.
In the mean time
Let's look at #2
Problem 2.
I suppose you also mean by 2.0N*s, right? (Nine ball moves off with 2.0 ...)
With that assumption..We can use those previous equations earlier.
Let a = cue ball and b = nine ball
I will just skew the coordinate system such that +x = direction of the cue ball, and +y = direction perpendicular to the cue ball. So:
Pa_x = 7, Pa_y = 0
Pb_x = 0, Pb_y = 0 (Because they're at rest)
What are P'a_x, P'b_x, P'a_y, and P'b_y? That is what you have to figure out. Show us what you're doing :-)
It seemed like a 1D collision problem to me, but the end condition is impossible given the starting conditions to start with. The second problem is far more plausible, of course. Nevertheless, it may be a good idea to check the first problem again and to see if it was typed in incorrectly.. cause I really think it may be impossible to do.
And yea, Nylex, I am kinda distracted at the moment, I should have caught that problem far earlier.
  • #31
I went back and checked. I tpyed what the book says. It seemed odd to my friend and I today as well. We wondered how a ball A could roll along completely horizontally, hit Ball B, have ball B continue on horizontally, and have Ball A deflect to a completely 270 degree direction.
  • #32
Better check with your teacher then, otherwise a lot of physics will have to be rewritten :P
  • #33
Welll, get out your pens, because i took a picture of the problem, and other than having a wrong number in my typing, which I fixed in my work, I typed it word for word. Apparently, this book has the power to defy physics. I will return later with the answers to question 2, but I need to go do some other work now. Thank you cyby for the help.
  • #34
Well, then the book is wrong. I trust physics over your book any day.
What book do you use, by the way? I am interested now :-)
  • #35
Well as I understand it, we don't have a lot of information about the details about the collision. The balls could have struck each other on the edge instead of through the center of mass. They could also have an electric charge or be irregularly shaped as far as we are concerned. In my book, collisions are sometimes denoted as "head-on" to specify that the momentum stays in one dimension. I don't see any laws of physics being broken here, it just may be messing with your intuition because you assume the collision to be head-on.
  • #36
At the same time, without some of these assumptions, the problem becomes unsolvable. But you make a good point in saying that we know little about the collisions. I guess I was a bit too rash in assuming a point mass collision.. a lot of things would happen if you don't assume that...
  • #37
You must regard both balls as physical objects with non-zero radii.
Now, consider what happens at the CONTACT POINT :
The incoming ball has a non-zero component along THE VECTOR NORMAL at the contact point, i.e unless an impulse directly counteracts this collision velocity, the incoming ball would pass into the other ball.
A collision where the impulse is solely in the direction of the contact normal, is called a normal impact.
As long as the contact normal is not strictly horizontally directed, the normal impulse would generate a vertical momentum component in either ball.
(but the SUM of these remain zero).
EDIT:
An important conclusion which can be drawn from this simple example, is that UNLESS you know the specific geometry of the objects involved, you really have no a priori way to detemine the direction the objects may leave.
That is, the collision should essentially be regarded as a RANDOM collision.
  • #38
Ok, sorry to bring this back up, but I need to get someone to straighten me out.
My teacher is telling me that the velocity of Ball B in this problem would be 3.6m/s. He is figuring that ball B is moving southeast at around a 45 degree angle when it makes contact with ball a. This would explain Ball A moving the direction it did, but when the problem specifically states that Ball B is at rest when struck.
Could someone please explain this to me? Because I thought if the 2Kg Ball B was struck at the 1 KG ball A moving at 3.0 m/s, the Ball B would have to move at less than the 3.0 m/s. Not more than it.
And for the record, I use the Merrill Physics: Principles and Problems. It is the black version.
  • #39
The key to this problem is that for elastic (not head-on) collisions between equal masses, the two masses move at 90 degrees to each other (see footnote)(a very useful principle if you play pool for money). And for inelastic collisions, the angle has to be less than 90 degrees. The angle can never be more than 90. And if energy is lost, it can never be 90.
So it is apparent that the first problem provides impossible facts because momentum cannot be conserved.
For the second problem, to conserve momentum, the cue ball must move with \vec v_{cue} = 2\hat i + 5\hat j. But this represents a seriously inelastic collision. Either someone stuck their gum on the object ball, or the guy that devised the problem has never played pool.
AM
(Footnote: Since \vec v_1 + \vec v_2 = \vec v_0 (momentum conserved) and v_0^2 = v_1^2 + v_2^2 (energy conserved) the vector diagram defines a triangle in which v0 is the hypotenuse whose length is related to the sides by the pythagorean formula. This means the angle between v1 and v2 is a right angle).
AM
