Calculate Normal Force in Mass M & m Slope System with no Friction
The problem involves a slope with mass M at an angle x degrees, on which mass m is placed. The slope is moving to the right with a constant acceleration a_0, and there is no friction involved. The objective is to determine the normal force between the two masses.
  • Participants discuss the effect of the slope's movement on the normal force, with one suggesting that the normal force would simply be N = mgcosx without considering the acceleration. Others raise the need to incorporate a fictitious force due to the non-inertial frame of reference.
Participants are exploring the implications of the slope's acceleration on the forces acting on mass m. Some have suggested using a free body diagram (FBD) to visualize the forces, including the fictitious force, while others are questioning how to properly represent these forces in their calculations.
There is a focus on understanding how to apply Newton's laws in a non-inertial frame, and participants are considering how to break down the fictitious force into components based on their chosen coordinate system.
mystmyst
We have a slope, with mass M, at x degrees. Mass m is on the slope. The slope moves right at constant acceleration [tex]a_0[/tex]. There is no friction between M and m, and no friction between M and ground.
Determine the Normal Force between M and m.
[PLAIN]http://img638.imageshack.us/img638/620/imaginaryforces2.png
I'm a bit confused with this because the slope is moving.
I would just think the answer would be N = mgcosx.
But since the slope is moving, I have to take into consideration [tex]a_0[/tex] but I don't know how to.
Can someone please help?
Thanks!
Hint: Use Pseudo force
Edit: For using Pseudo(fictitious) force, you have acc. of incline
These forces come into action when you need to apply Newton's laws in non inertial frame(i.e. a is not 0 of frame)
In this case it will be -mao, where - sign indiate that its direction is opposite to ao
hi mystmyst! :smile:
well, you know from the question that a fictitious force is involved …
what is that fictitious force in this case?
draw it on the free body diagram, and proceed as normal …
fictitious forces go on the fbd just like ordinary forces … that's the point! :biggrin:
The fictitious force is [tex]a_0[/tex] but I don't know how to draw it on a fbd. Am I supposed to split it into x and y coordinates (I'm using the slope as the x-axis...)
as the acceleration of incline is along +X ... so this fictitious force will be along -X
as i told you ...
write all other forces like gravity, normal rxn.. and also include this force in your FBD
a0 is horizontal, so you draw it horizontal
if you're using coordinates (you could use trig instead), then yes you'll have to split it into components along the axes you've chosen :smile:
Taking X along incline will be easier!
cupid.callin, he is taking X along the incline :frown:
OH! sorry :bugeye:
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 25 ·
