Calculate the area of water suspended at 500m to produce 23TWh
  • Thread starter Thread starter HorseRidingTic
    Area Water
The calculation for the area of water required to produce 23 TWh of energy at an elevation of 500m using the formula P=mgh indicates a need for a significant volume of water. The initial calculation suggested an area of 395m x 395m with a depth of 30m, which was identified as insufficient. A correction highlighted that the energy storage requirement is actually 23 TW-s, necessitating a volume 3600 times larger than initially calculated. This adjustment leads to a much larger area requirement, emphasizing the importance of accurate unit conversions in energy calculations.
  • Understanding of gravitational potential energy (P=mgh)
  • Familiarity with energy storage concepts, specifically pumped hydro storage
  • Knowledge of unit conversions between watt-hours and joules
  • Basic mathematical skills for area and volume calculations
  • Research pumped hydro storage systems and their efficiency metrics
  • Learn about energy unit conversions, specifically between joules and watt-hours
  • Explore the implications of energy storage on renewable energy integration
  • Investigate alternative energy storage methods beyond pumped hydro
Energy engineers, renewable energy researchers, and anyone involved in energy storage solutions will benefit from this discussion, particularly those focusing on large-scale energy management and calculations.
HorseRidingTic
Thread moved from the technical forums, so no Homework Help Template is shown.
Calculate the area of water, suspended at 500m, needed to produce 23TWh of energy
I've done a calculation but the answer seems far too small
If I needed to store the UK's supply of energy for three months i.e. 23TWh of energy
in a reverse pump hydro storage at an elevation of 500m
using
P=mgh
I've got an answer of 395m x 395m if the water was 30m deep but this seems way too small.
HorseRidingTic
How did you get that? Your answer is about 1250 swimming pools which would last 625 people about a year or 2500 people 3 months (assuming about 5.5 MWh per person per year). There are like 64 million people in UK so you need lots more, like 160^2 times more.
Edit I was looking at the 3 months maybe 85^2 times more for 23 TWh which is less than the 88 TWh I assumed.
I think that amount of stored energy is 23*10^12 J, or 23 TW-s, not 23 TW-h. You forgot the 3600 seconds in an hour, which will make the amount of water needed 3600 times larger.
