Calculate the average speed from a bar graph
To calculate the average speed from the provided bar graph, first identify the distances represented by the bars and the corresponding time intervals. The average speed can be computed by dividing the total distance by the total time taken. To find the percent difference between the bar graph and the line graph, subtract the average speed from each individual speed value, divide by the average speed, and multiply by 100. The discussion highlights the challenge of interpreting the graphs without clear images and emphasizes the need for a formula to facilitate these calculations. Understanding the relationship between the two graphs is crucial for accurate analysis.
Jath
Well I need to calculate the average speed from a bar graph and I do believe it said percent difference, then find the percent difference from the bar graph to my line graph. All I have is pictures of the bar graph, so can someone please tell me how to find the average speed and the percent difference? If you can thanks a lot. Sorry for the crappy pictures too.
http://s3.photobucket.com/albums/y71/Jath/?action=view&current=Physics1.jpg
http://s3.photobucket.com/albums/y71/Jath/?action=view&current=Physics2.jpg
It's difficult to understand the two graphs. There are 8 bars in one and 6 in the other. Do they represent the same time intervals, such that each bar has equal weight.
Assuming one has N quantities vi, then how does one determine the average value?
Then with the average value, take each vi, subtract the average, which will give the difference between the particular value and the average. How would one then determine the percent difference?
http://www.ugrad.math.ubc.ca/coursedoc/math101/notes/applications/average.html
http://en.wikipedia.org/wiki/Arithmetic_mean
Very sorry about that. The first picture on the left the numbers represent distance(cm) and the second picture represent the speed (cm/s). With the first picture too, the 2 strips that are the same length are the second and third from the left on the second picture. Right now this is velocity and it is testing with a spark generator(I think that's what it was). In lab we threaded this tape, a meter long, through the spark generator and tried to walk at a constant speed. Measured from 0-6(the dots created by the spark generator), 0-12, 0-18, 0-24, all the way up to 60 and then cut them at 6, 12, 18, 24, etc. Taped them onto this bar graph and now I got to find out the average speed and percent difference between this and the line graph I made. All I need is an equation there, I hope.
  • · Replies 40 ·
  • · Replies 20 ·
19K
