Calculate the force that each wire exerts on each other
  • Thread starter tasha_michelle
    Force Wire
4 replies · 2K views · last reply
tasha_michelle
need help asap...by 2:30 :(
if 2 parallel conductors with the same length of .05m have their currents going in opposite directions, one conductor carries a current of 10A. C=D/3, D=24cm, I is adjusted so the magnetic field @ C=0.
a. find the value of the current I
b. value of magnetic field @ point A (find magnitude & direction)
c. calculate the force that each wire exerts on each other
What is the formula for the magnetic field strength as a function of current and geometry.
I take it that C = D/3 is measured from the wire with the 10 A current? Then the distance from C to the other wire is 2D/3.
Does this look familiar - http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magcur.html
Umm - where is A? One can use superposition of fields.
A is at the midpoint of the first wire...
A
I <---------------------
--------------------->10A
C
a is at the midpoint of the first wire, C is at the midpoint of the second wire...what is the equation?
