Calculate the number of revolutions the disc makes
  • Thread starter Thread starter kingyof2thejring
    Disc Revolutions
The discussion focuses on calculating the number of revolutions a disc makes when subjected to opposing torque after reaching a certain angular velocity. The disc has a moment of inertia of 29.1 kg m² and is initially rotating at 8.0 rad/s. An opposing torque of 13.2 N m is applied to decelerate the disc. The solution involves using rotational kinematic equations analogous to linear kinematics, ultimately leading to a final angular displacement of 14.515 radians before the disc comes to rest.
  • Understanding of rotational kinematics and dynamics
  • Familiarity with torque and moment of inertia concepts
  • Knowledge of Newton's second law for rotational motion
  • Ability to apply kinematic equations in both linear and rotational contexts
  • Study the relationship between torque, angular acceleration, and moment of inertia
  • Learn how to derive and apply rotational kinematic equations
  • Explore the effects of opposing torque on angular motion
  • Investigate practical applications of rotational dynamics in engineering
Students and professionals in physics, mechanical engineering, and anyone interested in understanding the principles of rotational motion and dynamics.
kingyof2thejring
A disc of moment of inertia 29.1 kg m2 is made to rotate about an axis through its centre by a torque of T . The disc starts from rest and, after {t} s, has kinetic energy {k} J.
The torque is removed when the disc is rotating at 8.0 rad s-1 . An opposing torque of 13.2 N m is applied to slow the disc down.
Calculate the number of revolutions the disc makes after the second torque is applied, before it comes to rest.
how do i approch this problem (if numbers were involved) i would have to calculate the angular acceleration and then tention. after t seconds
any help would be apprecated thanks in advance
This is a problem in rotational kinematics.
Could you do it if it were a problem in linear kinematics, in other words, suppose you have a mass of 29.1 kg, with an initial speed of 8 m/s and a resisting force of 32.2 N, could you work out the distance traveled until it stopped ?
What (kinematic) eqns would you use to solve that problem ?
The eqns needed for the rotational problem are identical in form with their linear counterparts.
e.g.
s = ut + (1/2)at² - linear
θ = ωt + (1/2)αt² - rotational
If you know the eqns to use for the linear problem, then just convert them to their rotational equivelents.
hi, er... well... I've got the following data...
s=?
u=8
v=0
a=? (-8/t)
t=?
s= ut + 0.5at^2 ------> s= 4t
is the initial force equal to the resisting force. so that the force at the end equals 0
The resisting force is the decelerating force and is constant throughout the travel, s, of the mass.
Use Newton's 2nd law, F = ma, to get a numerical value for the deceleration. call it a.
You need to use another kinematic eqn as well, though.
It's time I got some sleep (it's 1.00 a.m. here) so it's time I was off. Here's how to do it.
Use the eqn of motion,
v² = u² - 2as
where v is the final velocity (v = 0) and u is the initial velocity (u=8) and a is the deceleration (a = -2.2045 m/s²).
You will get a distance moved of,
s = 14.515 m
Now all you have to do is write out the solution using rotational eqns of motion.
Substitute for,
s = θ
u = ω
a = α
The numerical values in your rotational eqns will be identical to those used in the linear eqns and the final angular displacement will be θ = 14.515 rads.
If you have been having any problems handling rotational eqns of motion, then after you've done it this way a few times, you will be able to just use the rotational eqns of motion straight away.
  • · Replies 22 ·
