Calculate the torque required to rotate a pipe
The discussion focuses on calculating the torque required to rotate a pipe, considering factors such as weight, angular velocity, and time. Participants explore the relationship between torque, angular acceleration, and mass moment of inertia, while addressing unit conversions and calculation methods.
  • Mike initially seeks guidance on calculating the torque needed to rotate a 30 lb pipe at constant speed and questions whether a sensor is necessary for measurement.
  • One participant explains that torque relates to angular acceleration and that the force required to maintain constant speed must overcome friction, particularly in the bearings.
  • Mike provides a detailed specification of the pipe and calculates torque based on mass moment of inertia, expressing concern that his initial torque value seems too high.
  • Another participant points out unit errors in Mike's calculations, emphasizing the need to distinguish between weight and mass and to use appropriate units for mass moment of inertia.
  • Mike revises his calculations, converting mass to slugs and recalculating torque, but is still questioned about the accuracy of his unit conversions.
  • After further adjustments, Mike presents calculations in both English and metric units, noting a significant difference in torque values and expressing uncertainty about whether the results are too low.
  • A participant reassures Mike that his calculations are consistent across both unit systems, suggesting that he should have confidence in the results.
Participants do not reach a consensus on the accuracy of Mike's calculations, as there are ongoing discussions about unit conversions and the correctness of the torque values derived. Some participants agree on the importance of careful unit handling, while others express differing views on the results.
Limitations include unresolved issues regarding unit conversions, particularly the treatment of weight versus mass and the appropriate gravitational constant. There are also concerns about the accuracy of the torque values calculated based on these conversions.
vtmike
Hi,
I am stuck on what should be a fairly simple problem. I need to calculate the torque required to rotate a pipe weighing 30 lbs resting on bearings at constant speed. How should my approach be? Do I need to actually measure the torque required using a sensor?
Thanks,
Mike
The problem that you're more than likely running into is that torque or moments cause angular acceleration. The relation is analagous to F=ma, where rather than a force, we have a moment; a mass moment of inertia rather than mass, and angular acceleration rather than linear acceleration.
The force needed to maintain constant speed will be the force needed to overcome friction. Your main frictional forces will be in the bearings, which calculating decent numbers may be tricky.
My problem specification is as follows:
mass, m = 300 lbs
Hollow tube with OD = 6" & ID = 5"
Initial angular velocity W1= 0 rpm
Final angular velocity W2= 20rpm
Change in time, Delta t = 3sec
So using,
I=(m(OD^2 + ID^2))/2 = 9160 lb-in^2
Angular acceleration, alpha = (W2-W1)/delta t = 6.67 rad/s^2
Torque, T = I*alpha = 61031 lb-in
I think the torque value looks too high...Do you see any problem in my procedure?
Look at your units:
You have (lb-in^2)*(rad/s^2) [=] lb-in^2/s^2
which is not the in-lb you claimed for the resulting torque.
The problem is that you did not compute the mass moment of inertia. Instead you computed a quantity usually called Wk^2, the weight * radius of gyration^2. The relation you need is
I = Wk^2/g = Mk^2
This is a result of confusing weight and mass. If you have a quantity expressed in pounds (lb), it is a weight or a force. If it is a mass, in the US Customary system it will either be in slugs, or if you are working in inches, the units for mass will be (lb-s^2/in). (Yes, I know it seems awkward, but that is just how it is!)
Thanks for the reply! Yes you are right...Here is my updated calculation,
mass, m = 300 lbs = 9.324 slug
Final angular velocity W2= 20rpm = 2.094 r/s
So using,
I=(m(OD^2 + ID^2))/2 = 284.38 lb-in^2
Angular acceleration, alpha = (W2-W1)/delta t = 0.7 rad/s^2
Torque, T = I*alpha = 200 lb-in
This torque value looks sensible. Does this look right?
Thanks,
Mike
You still have an error because you used the wrong value for g. Look at your units for I.
You have slug-in^2 [=] (lb-s^2/ft)*in^2
Your units don't work.
You needed to get the mass in units of lb-s^s/in, and to do that you have to express g in units of in/s^2, not ft/s^2. Your torque value is still considerably too high.
You really do need to check your units, really check them, carefully, if you want to get correct results. You could have saved yourself a lot of time on this problem if you had paid attention to the units.
Thanks for the input! I really appreciate it!
I redid my calculations and verified them by working in metric. here they are:
In English units:
mass, m = 300 lbs = 300/386.4 = .7764 slug (lb-s^2/in)
So using,
I=(m(OD^2 + ID^2))/2 = 23.68 lb-s^2-in
Torque, T = I*alpha = 16.7 lb-in
In Metric Units:
mass, m = 300 lbs = 136.07 kg
Hollow tube with OD = .1524m & ID = .127m
So using,
I=(m(OD^2 + ID^2))/2 = 2.67 kg-m^2
Torque, T = I*alpha = 1.87 N-m = 16.6 lb-in
Significant difference and now I'm not sure if it is too low. But the calculations seems ok now
Thanks Again,
Mike
You really should have considerable confidence in these calcs by now. You have done them in two different unit systems and gotten essentially the same result (the difference is probably in the slight difference in your value for g). If it is any consolation, this is the result I got also.
10K
13K
