Calculate velocity of streams impinging at differing angles
  • Level: Graduate
  • Thread starter Thread starter rdemyan
    Momentum
30 replies · 3K views
A.T. said:
You can always transform into a reference frame, where the fluid in one of the incoming streams is initially at rest, while the fluid in the other stream initially moves along one axis only. Then you solve the (potentially simpler) problem there, and transform the resulting outgoing velocities back to the original frame.
Just don't confuse the direction of the velocity of the fluid in a stream with the orientation of the stream. They are parallel in your original frame, but not necessarily in other frames.
I'm going to try to switch to the zero momentum frame of reference. Should I start a new thread as I am definitely going to need help?
