Calculating Acceleration of Hanging Mass System
9 replies · 3K views
physicos
A hanging mass M1 =1 kg is attached by a light string that runs over a frictionless pulley to a mass M2=2 kg that is initially at rest on a frictionles table .
What is the magnitude of the acceleration a of M2 ?
I used for M1 :
Fg1 + T =M1a (with T tension of string)
and for M2 :
N+Fg2+T=M2a
NOW I'm stuck , I can't solve it , any help ??
physicos said:
and for M2 :
N+Fg2+T=M2a
For M2 you have added forces that are perpendicular to each other. Don't do that! Instead, consider horizontal forces separately. (Assuming the table is horizontal, that's the direction of the acceleration.)
Be careful with signs.
What I have written are vectors :
for M1 without vectors :
_m1g+T=-m1a
and for M2 :
N+T-m2g=m2a
I still didn't get your point
_m1g+T=-m1a
Good. (Note that the forces of gravity and tension all act vertically.)
and for M2 :
N+T-m2g=m2a
This combines vertical forces (N, mg) with horizontal forces (T). Don't do that.
physicos said:
I thought T was a vertical force too
On mass 1 it is a vertical force. On m2 it is pulling from the side. Remember that since your pulley is massless and frictionless, the tension along the string will be completely constant.
Not when it acts on M2, which slides along a horizontal table. (A picture would help.)
The OP doesn't actually state the orientation of the string between pulley and M2. Yes, it's probably meant to be horizontal, but in principle could be anything.
so what am I supposed to do ? Cause that's all what is available in the problem statement , there is no picture : Should I work with it as a horizontal force ?
Yes.
