Calculating Bearing Load for Linear Slides: Equation and Examples
tomsdubs
Need to know the bearing load for a linear slide I'm working on, two spaced bearings with an extended load off the end of the slide.
What equation do I need to apply? What examples are out there?
You need to apply the equations of static equilibrium to determine R1 and R2.
I'm still not sure how to apply, I can't find any relevant examples. The two distances are 1.5m and 1m, bearing spread and mass extended.
R1 = 1/2.5*(30*1) = 12kg
R2 = 1/2.5*((30*2.5)+(30*1)) = 42kg
This is how I've done it, if anyone can give me some guidance that'd be great.
Use equilibrium equations
Lets assume both reactions (R1, R2) are facing upwards.
Now we do the sum of forces in the Y direction=0, where upwards is positive.
So, Sum of Fy=0: R1 + R2 - 30=0
Now let's take the sum of the moments at point 1 equal to zero, where anti-clockwise is positive.
So, Sum of M1=0: (1.5)(R2) -(2.5)(30)= 0
(1.5)(R2)=75
R2= 75/1.5
R2=50kg
Substituting in the 1st equation:
R1 + 50 -30 =0
R1 +20=0
R1= -20kg
So your reactions R1 and R2 are -20kg, 50kg respectively.
