MHB Calculating Boat Costs: Splitting 60/40 & Time Usage
The discussion revolves around calculating the actual weekly cost of boat maintenance when costs are split 60/40 between two friends. One friend pays 60% of the costs but uses the boat less frequently, having it 5/8 of the time compared to the other friend's 3/8. It is clarified that despite the time usage, the agreed cost split means the first friend pays 60% of the total maintenance cost. However, based on usage, the first friend should actually be responsible for 62.5% of the costs. The conclusion emphasizes that the time spent using the boat impacts the fair distribution of costs.
ger1
Hi, I am struggling with a calculation.
A boat costs x to maintain and I and a friend decide to split the costs 60/40, where I put in 60% of the cost.
However, I will have the boat less than my friend, he will have it 3/8 of the time and I will have it 5/8 of the time.
So what is my actual cost on a weekly basis - it doesn't seem right to just multiply 60% by 5/8.
Mathematics news on Phys.org
You mean your friend will have the boat less than you since 3/8< 5/8. But if you have already agreed to pay 60% the "5/8 versus 3/8" is irrelevant. The cost to you is .6 times x.
(5/8= 0.625 or 62.5%. You should actually be paying 62.5% of the cost!)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
