Calculating Bullet Speed: Pendulum Physics Homework Problem Solution
  • Thread starter Thread starter BugsSport
    Pendulum Physics
To calculate the speed of a bullet lodged in a log, the relationship between kinetic energy (KE) and potential energy (PE) is essential, specifically using the equation ½mV² = mgh. The horizontal displacement, weight of the log, and string length provide the necessary parameters for the calculation. The discussion highlights the importance of understanding pendulum physics to solve the problem effectively. A resource link is shared for further assistance with pendulum-related calculations. Ultimately, the problem can be solved by applying the correct energy principles.
BugsSport
I have to calculate the speed of a bullet, based on the amount of displacement created when the bullet becomes lodged in the log.
I have the horizontal displacement, the weight of the log, and the length of the string.
I'm not sure how to set this up so I don't know what equations to use yet.
I calculated the horizontal displacement and have enough information to finish the problem, but I'm not sure which equations to use. Any start is appreciated, thanks.
KE = PE
The ½mV² of the bullet becomes the mgh of the log displacement.
You know L and θ apparently so ...
I just figured it out. Thanks for the response though
Just for future reference, this page helps a lot in pendulum problems
http://www.rowan.edu/colleges/lasold/PhysicsAndAstronomy/LabManual/labs/EnergyInAPendulum.pdf
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
