Calculating Charge Density and Total Charge Using Gauss's Law
  • Thread starter Thread starter spaghetti3451
    Gauss's law Law
spaghetti3451
Suppose the electric field in some region is found to be [itex]\vec{E} = kr^{3} \hat{r}[/itex], in spherical coordinates (k is some constant).
(a) Find the charge density ρ.
(b) Find the total charge contained in a sphere of radius R, centered at the origin. (Do it two different ways.)
(a) Use the formula for the divergence of a vector in spherical basis to get [itex]\nabla . \vec{E} = 5kr^{2}[/itex] so that [itex]\rho = 5k\epsilon_{0}r^{2}[/itex].
(b) Q is the volume integral of [itex]\rho[/itex] over the volume of the sphere. So, we integrate over d[itex]\phi[/itex], integrate sinθ over dθ, integrate the [itex]\rho[/itex] times [itex]r^{2}[/itex] over dr and multiply the three results. The process gives us 4[itex]\pi \epsilon_{0} R^{5}[/itex].
Q can also be found using the integral form of Gauss's law, where the surface integral of the electric field is taken with the infinitesimal area, which is R2 sinθ dθ d∅ r, where r is the unit vector in the radial direction. We take the constants out of the integral and integrate 1 over phi and sinθ over theta to obtain the same Q as above.
Please could you check if the process and the answers are correct?
a) Looks good to me. I get the same.
b) Is it a hollow spherical shell. Then you can use that the electric field is constant over the surface(fixed r) and only multiply by the area of the sphere(shell) because:
[itex]\oint \vec{E}\cdot\vec{da} = \oint E\,\text{d}a = E\oint 1\text{d}a = E 4\pi R^2 = Q/\epsilon_0 \Leftrightarrow Q = 4\pi \epsilon_0 kR^5[/itex]
The dot product [itex]\vec{E}\cdot\vec{da}[/itex] is just da times E cause they point in the same direction.
