Why Is My Electron-Positron Scattering Cross Section Calculation Incorrect?
The discussion centers on the calculation of the cross-section for electron-positron to muon-antimuon scattering. The initial calculation yielded an incorrect result, prompting the poster to seek assistance. Key issues identified include the integration limits and the proper use of the solid angle element, with clarification that dΩ is equal to sin(θ)dθdφ. The correct integration approach involves integrating over both θ and φ, leading to the accurate cross-section formula. The conversation highlights the importance of correctly applying integration techniques in particle physics calculations.
Muh. Fauzi M.
I have a problem in calculating cross-section in elektron-positron -> muon-antimuon scattering.
In the relativistic limit, we find the differential cross-section of {e}+{e^-} -> {μ}+{μ^-} is
\frac{d\sigma}{d\Omega}=\frac{\alpha^2}{4s}*(1+cos^2{\theta}).
When I integrating over \theta, i get an answer:
\sigma=\frac{3*\pi*\alpha^2}{8*s},
but that is not the correct answer. Due to my reference (Halzen and Martin), the answer should be
\sigma=\frac{4*\pi*\alpha^2}{3*s}.
Can someone help me through this problem? My intuition said I have mistaken the integration. But I've tried to re-integral-ing it, still not come up with correct solution.
Muh. Fauzi M. said:
I have a problem in calculating cross-section in electron-positron -> muon-antimuon scattering.
In the relativistic limit, we find the differential cross-section of ##\ \ {e}^+{e^-} -> {μ}^+{μ^-}## is
$$\frac{d\sigma}{d\Omega}=\frac{\alpha^2}{4s}\left (1+cos^2{\theta}\right ) \ .$$
When I integrate over ##\theta##, I get an answer:
$$\sigma=\frac{3\pi\alpha^2}{8s}\ ,$$
$$\sigma=\frac{4\pi\alpha^2}{3s}\; .$$
Can someone help me through this problem? My intuition sais I have mistaken the integration. But I've tried to re-integrate it, still not come up with correct solution.
Hello,
Is ##d\Omega## just ##d\theta## or has ##\phi## something to do with it too ?
Anyway, show your steps in detail, please. That makaes it easier to follow and point out where things may go wrong...
BvU said:
Hello,
Hello Mr., thank you for your respond.
In my first reference (Halzen and Martin), the instructor is to integrate over ##\theta## and ##\phi##. Here is my doodling:
$$ \sigma = \frac{\alpha^2}{4s}\int{(1+cos^2{\theta})}d\theta d\phi $$
Substituting the trigonometry identity,
$$ \sigma = \frac{\alpha^2}{4s} \int {\frac{(3+cos{2\theta})}{2}} d\theta d\phi $$.
Dividing the integration,
$$ \int 3 d\theta d\phi , \quad \int {cos{2\theta}}d\theta d\phi $$
and integrating from ## 0 ## to ## \pi ## for ##\theta##, ##0## to ##2\pi## fpr ##\phi##. The second term is vanish, so I have
$$ \int 3 d\theta d\phi=3(\pi)(2\pi)$$.
Thus, when inserting to ## \sigma ##, I have
$$ \sigma = \frac{3\pi^2\alpha^2}{4s} $$.
Using my second ref (Schwartz), the integration just applied over ##\theta## and I get
$$ \sigma = \frac{3\pi\alpha^2}{8s}$$.
Which step do I miss?
If I remember well, ##d\Omega \ne d\phi d\theta ## because then you would end up with ##2\pi^2## where you expect ##4\pi## . Wasn't it ##d\Omega = \sin\theta \;d\theta d\phi ## ?
Speechless. That's true Mr. Thank you very much. (shy)
