Calculating Current using Kirkoff's Rules
  • Thread starter Thread starter MasterVivi
    Current Rules
7 replies · 2K views
MasterVivi
Apply the loop rule to two of the three loops to calculate I1,I2,and I3.
Picture of DC circuit involved
V=IR
L1=2v+2I2-4I1=0 (simplified)
and
L3=4-4I1-5I3=0
But if you work through the algebra you'd get
I2=1
which would then make
I1=1
which does not work for the junction rule of
I3=I1-I2 cause that is 0.
The rules still confuse me when look at some of the resistors on the right side I can tell which way current flows, obviously did it wrong though, any help would be appreciated.
mastervivi said:
3. The Attempt at a Solution
loop 1 --> 2v+2[/color]i2-4i1=0 (simplified)
1Ω + 3Ω ≠ 2Ω
Okay, re-attempted using loop one and loop two, does, this seem more accurate?
L1=12V-I1(2)+I2(1)-10V+I2(3)-I1(1)=0
L1=2V-4I1+4I2=0
L2=-3(I2)+10V-I2(1)-I3(1)-8V-I3(2)=0
L2=2V-4I2-5I3=0
L2=2-4I2-5(I1-I2)=0
L2=2-4I2-5I1+5I2=0
L2=2-5I1+I2=0
So from there
I2=5I1-2
Finally plugging it all through
I1=I2+(1/2)[From the first loop equation]
I1=5I1-2+(1/2)
I1=(3/8)
if that's true
I2=5(3/8)-2=(-1/8) [Is a negative current okay?]
and from there
I3=I1-I2=(3/8)-(-1/8)=1/2
The negative current for I2 feels wrong, did I mess up any of the loop equation or any algebra along the way?
For the second loop, it should be +5I2, not -5I2
As for there being a negative current, it just means it's flowing in the opposite direction from what you set it up as in the problem.
Okay, think I got it
You're right it should be +5I3 because it's with the current, just like I2 works out in the first loop equation
L1=2-4I1+4I2=0
Using this to solve for I1
I1=I2+(1/2)
Now I did this wrong, so going back through the derivation of this loop equation
L2=-3I2+10-I2+2I3+I3-8+2I3=0
2-4I2+5I3=0
2-4I2+5(I1-I2)=0
L2=1+5I1-9I2=0
Using that to solve for I2
I2=(5/9)I1+(2/9)
Solving for the numerical value of I1
I1=((5/9)I1+(2/9))+(1/2)
I1=(5/9)I1+(13/18)
(4/9)I1=(13/18)
I1=(13/8)
Solving for the numerical Value of I2
I2=(5/9)(13/8)+(2/9)
I2=(9/8)
Which Finally implies
I3=I1-I2
I3=(13/8)-(9/8)=(1/2)
Aye?Nay?
correct
quick note: you had I1=I2+1/2, so you could have easily figured out I3 right then and there. I3 = I1-I2 = I2+1/2-I2 = 1/2
frogjg2003 said:
correct
really?
MasterVivi said:
L2=1+5I1-9I2=0
I1=(13/8)
I2=(9/8)
Aye?Nay?
L2=1+5I1-9I2=0
i1=13/8
i2=9/8
ergo:
1+5*(13/8)-9*(9/8)=0
8/8+65/8-81/8=0
73/8-81/8=0
-8/8=0
-1=0 ?
Don't all 4 equations have to come out correctly?
