Calculating currents homework question
  • Thread starter Thread starter jersey
    Currents Homework
The discussion revolves around a closed circuit containing seven bulbs with unequal resistances. The original poster has three known currents (300mA, 200mA, and 500mA) and seeks to determine four unknown currents flowing through points A, B, C, and D. The problem involves applying the loop and junction rules in circuit analysis.
  • Participants discuss the application of the junction rule to find unknown currents, with some suggesting the "inspection" method. There are attempts to set up equations based on the known currents and the relationships between them.
Participants are actively engaging with the problem, exploring various interpretations and calculations for the unknown currents. Some guidance has been offered regarding the application of the junction rule, and there is a recognition of the importance of understanding current flow in the context of the circuit.
There is a mention of the requirement that all resistances are unequal, which raises questions about the validity of certain calculated currents. Participants are also navigating the complexity of multiple junctions within the circuit.
jersey
I have a closed circuit, with 7 bulbs, all of unequal resistances. I know three currents, 300, 200 and 500. I have 4 unknown currents, those fllowing through A, b, C and D which I need to find.
There is a graphic for this which I don't know how to insert, but the link to go to it is:
http://www.lightandmatter.com/bk4c.pdf
GO to the link, scroll to page 123, and the diagram is problem 17.
Loop rule where sum voltages in a closed loop = 0
Junction rule where the sum of currents flowing into and out of a point=0.
I started by labelling the known currrents, from the left, G E and F, giving me a name for each one.
I know I need to use the junction rule to calculate the currents and I have this:
Rg+Re+Rf = Ra+Rb+Rc+Rd
1000= Ra+Rb+Rc+Rd
I need to come up with 4 equations for each unknown, so I have:
Ra=1000-Rb-Rc-Rd
Rb=1000-Rc-Rd-Ra
Rc=1000-Rd-Ra-Rb
Rd=1000-Ra-Rb-Rc
then i need to use substitution to solve each one, but the maths is getting lost on me. Can anyone help? Am i in the right direction?
I really appreciate any assistance you can give me to work this out.
You can use the "inspection" method (plus the junction rule) to solve this one. For a 3-path junction, if 300mA is going into the junction from one path, and 200mA is coming out of the second path, then what must be going on with the 3rd path?
Thank you for your replying. I'm not sure what to do next?
The juction rule says that the sum of all currents entering or exiting a junction is zero. Take some time and wrap your mind around that rule (Its important and comes up a lot in circuit analysis).
So, if you have a junction consisting of 3 wires, the currents must add up to zero.
Unless I'm looking at the wrong problem, I see such a junction in the middle of your circuit.
A convention that is helpful is to declare current going into a junction "positive" and current going out "negative"
So, for that center junction we have:
(+300) + (-200) + (X) = 0
Solve for X.
Thanks. I'm making it so much harder in my head so it;s good to see it like you put it,
So I have x=-100.
what about my other?
Same principle applies. Give it a try, then I'll comment.
Thankyou so much!
for the top junction To find A, I have
200+(-500)+A=0
-300=-A
(but this can't be right cause it's the same as one of the given resistances and they're all supposed to be unequal!)
Next, is C.
IF B is 100mA, and I have 500mA then
500 + (100) + c=0
-600=C
How am I going?
for the top junction to find a, i have
200+(-500)+a=0
-300=-a
300 = a
hang on for A
200+ (-300)+A=0
-100=-A
A=100
BUt I'm stuck for D
600 + D= 0
D=-600
I thought we agreed that "A" (the current going into the upper junction from A) was 300mA.
Not sure where "A=100" is coming from.
To get D, you could either look at the leftmost junction or the rightmost junction.
The question states that each of the resistances is unequal. It can't be 300mA as that is the resistance of one of the given bulbs.
For D I have 500+600+D=0
D=1100
So, the 4 unknown currents shown are:
A=?
B=100mA
C=600mA
D=1100mA
HOw does that look?
correction - it doesn't say anythging about currents not being the same does it.
So I have:
centre junction:
300 + (-200) + B= 0
B=100 mA , moving away from that junction.
TOP Jnction
(200)+(-500) +A=0
A=300mA moving into the junction
to find c
500+100+C=0
C=-600mA
and d?
If you know the current going through bulb B (100mA) then you know exactly what the current through bulb C is, yes?.
To continue... With your knowledge of the current going through bulb C, you can do the junction current equation for the rightmost junction and get the current running through bulb D, yes?
C is 100mA
using this information, i then have
100+100+500+D=0
700+D=0
D=-700
OMG? do I have it? Sorry I'm so slow with this, I really appreciate you sticking with me.
C is 100mA
100+100+500+D=0
700+D=0
D=-700
Why do "100 + 100" ? Current is like water flowing through a pipe.
If you have 100mA flowing through bulb B, then you have 100mA flowing through bulb C, then you have 100mA flowing into the rightmost junction from that wire.
You are real close.
I see! So C is 100mA
To find D
100+500+D=0
600+D=0
D=-600mA
D=600mA moving away from that junction
Yes!
To complete your understanding of this, we have been referring to the "rightmost junction", the "middle junction", etc. for the sake of being clear. These are 3-wire junctions, where the interesting activity is happening.
But there are other 2-wire junctions that are less interesting like the one between bulb B and bulb C (shown as a single connecting wire for simplicity). The same junction rule applies, the sum of the currents must equal zero. For this junction:
(+100) + (-100) = 0
Seems trivial, but maybe it will help with your understanding.
OK, I haev added that line into my workings and I can see exactly what you mean. You even picke dup the bits that I was not understanding.
I can't thank you enough! Seriously, I totally get it now. Sorry that took me so long ot grasp. Thanks a lot.
9K
  • · Replies 28 ·
