Calculating density using temp. and salinity?
  • Thread starter Thread starter thethedev
    Density
To calculate the density of water using temperature and salinity, a specific formula can be utilized, which incorporates coefficients dependent on temperature. The formula includes variables for temperature and salinity concentration, with coefficients that adjust based on the temperature's influence on density. A source provided in the discussion offers a JavaScript function that outlines the calculation method. Users are encouraged to reverse engineer this formula for their specific needs. Understanding this formula allows for accurate density calculations based on varying temperature and salinity levels.
thethedev
Hi
Does anyone know how to work out the density of water using just the temperature and the salinity?
There must be a formula as I've found a few sites that do the conversion for you but I need the actual formula.
Any help at all is appreciated thanks
Maybe not much help but my web browser allows me to view the web page source which for the following page has the formula as part of the web page:
from
http://www.csgnetwork.com/h2odenscalc.html
function rhoscalc (rho,conc,temp) { // temp and conc dependent density
var rhos, A, B, temp;
A = 0.824493 - 0.0040899*temp + 0.000076438*Math.pow(temp,2)-0.00000082467*Math.pow(temp,3) + 0.0000000053675*Math.pow(temp,4);
B = -0.005724 + 0.00010227*temp - 0.0000016546*Math.pow(temp,2);
rhos = rho + A*conc + B*Math.pow(conc,(3/2)) + 0.00048314*Math.pow(conc,2);
return rhos;
You might be able to reverse engineer the formula you need?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 24 ·
  • · Replies 84 ·
