Calculating Energy Between Objects
  • Thread starter ryty
    Energy
ryty
Two 0.54-k basketballs, each with a radius of 16 cm, are just touching.
A. How much energy is required to change the separation between the centers of the basketballs to 1.0 m?
B. How much energy is required to change the separation between the centers of the basketballs to 14 m?
Im not sure what to use, but its probably obvious
None, i don't know where to start
this smells like a universal gravitational potential problem (assuming these balls are not on the surface of the earth), so what is your potential equation?
okay, F=G(m1)(m2)/r^2 but if the raduis of the balls are .16 m, do i use that as the radius, or do i double it beause the balls are the same size?
(ignoring the detail with the radius) your expression solves for the force one ball exerts on another. Once you solve for this force, what good is it?
no, use this equation.
[tex]U=G\frac{m_1m_2}{D}[/tex]
where:
U= potential energy
G= Newton's gravity constant
D= distance from either respective centers
so it should look like this F=(6.67E-11)(.54)(.54)/.16 ?
