Calculating excess charges on Earth's surface?
14 replies · 4K views
fluidistic
The electric field on the Earth' surface is not null. Assume that the intensity of the field on Earth' surface is 300 N/C pointing in Earth's center. Calculate the excess of charges in Earth' surface giving the result in terms of electrons per [tex]m^2[/tex].
Don't know.
I'm stuck at starting the problem. How can the electric field point in Earth's center? Charges must be at the surface so I've no clue about the direction of the field.
I also do not have any idea about which formula to use.
Maybe [tex]E=A \cdot \sigma[/tex]? So [tex]4 \pi r^2 \sigma= \frac{300N}{C} \Rightarrow \sigma =\frac{100}{6300^2 \cdot \pi}[/tex]. But a dimensional analysis shows that I'm wrong. I get that the units of this are [tex]\frac{kg}{s^2Cm}[/tex] which clearly isn't a surface charge density. (I should get [tex]\frac{C}{m^2}[/tex] I guess.)
Hi fluidistic! :smile:
Because the situation is spherically symmetric, so wherever you are, the field will be radial.
Hint: now draw a sphere around the earth. :wink:
Ah I see. Despite the fact that there's no charge inside the sphere (Earth), there can be an electric field. I still do not realize why the field lines are radials. I could imagine them to be different and still symmetric.
Hmm I don't see why.
I don't think I've to calculate the electric flux passing by Earth' surface.
Can you give me a little more hint?
Thanks for your help!
How? :confused:
You don't have to … but what harm could it do?
You know how much flux is going through the whole of the (outer) sphere, whatever its radius is, don't you?
tiny-tim said:
How? :confused:
See the picture I uploaded. I wrote a point "A", but do the same with all points on the sphere' surface. (Although I agree I did it for a circle but I'd keep the same idea for a sphere).
[tex]\Phi = \int _S Eda[/tex] where [tex]S[/tex] is the sphere' surface and [tex]E[/tex] is the electric field that I don't know.
[tex]da[/tex] would be an area element (I remember it's worth [tex]\rho ^2 \sin \phi d \rho d\phi d \theta[/tex])
But I think it can be simplified here, the flux would be [tex]4 \pi r^2 \cdot E[/tex] or something like that. But I don't know [tex]E[/tex].
I've also seen the formula [tex]\Phi = \frac{Q_ {\text{enclosed}}}{\varepsilon _0}[/tex] but [tex]Q _{\text{enclosed}}[/tex] is [tex]0[/tex]... hence there's no flux passing through the sphere. It makes no sense! So I guess that [tex]Q[/tex] enclosed is not [tex]0[/tex].
I'm all confused as you can see.
Qenclosed (btw, isn't that easier than using LaTeX? :wink:) by the outer sphere isn't zero …
… there are electrons all over the Earth's surface. :smile:
Ahh... I see. That's why you asked me to draw a sphere around the Earth.
I don't really know how to calculate [tex]Q _{\text{enclosed}}[/tex]. I'm sure it's related to the intensity of the electric field on Earth' surface.
I give a try : Q is the sum of all the charges. Each charge is worth [tex]-1.6 \cdot 10^{-19}C[/tex].
I'm sorry I don't reach anything.
Do you know the formula for the electric field at a distance r from a point charge? A sphere is identical to a point charge in every respect, as long as we're not talking about the interior of the sphere. (That's why the formula F=GMm/r2 applies to planets, even though it assumes point masses.)
Oh thanks. Yes I know it ( I believe!), is it [tex]k \frac{q}{r^2}[/tex]?
So for the sphere I replace [tex]q[/tex] by [tex]Q[/tex]. But on the surface of the sphere, [tex]r=0[/tex] since you consider it as a point mass, right?
If so I'm lost.
No, r is the distance from the sphere's center, just as it is in the formula F=GMm/r^2. At the surface, r would be Earth's radius.
Ah ok! So I guess this mean that the electric field at the surface of the Earth is [tex]k\frac{Q}{(6300000 m)^2}[/tex]. I can equal this to [tex]\frac{300N}{C}[/tex] (checking out the units of course) and I can get Q. Then I would divide it by [tex]4 \pi \cdot 6300000^2[/tex] in order to get the charge per meter squared. I would divide this result by the charge of the electron in order to reach the result.
I hope I'm not mistaken.
Thanks to both.
Out of curiosity, does the image I posted in the post #5 makes sense?
I mean, for me it's not natural to think that the electric field lines are radial in a sphere. I should let my intuition absorb this.
Consider a small area Δs on the Earth's surface. Consider a Gaussian surface in form of a cylinder enclosing this surface perpendicular to the Earth's surface.
If ρ is the surface charge density, charge Δq on Δs = ρ*Δs.
One surface of the cylinder is inside the Earth and the other surface is out side. So total flux is E*Δs = Δq /εο = ρ*Δs/εο
Hence E = ρ/εο . Now find ρ. The excess electron is given by ρ*A/e, where A is the area of the sphere and e is the charge on an electron.
(I hadn't seen the image when I made my post #6)
sorry, fluidistic, but i don't understand that image …
is that the surface of the sphere, or the interior of it?
either way, i don't see what's symmetrical about it :redface:
Ok thanks a lot.
It was the interior of a circle. The sketch is not complete, but would you forget about it ?:shy:
