Calculating FFT for discrete values
The discussion revolves around calculating the Fast Fourier Transform (FFT) for a discrete set of values defined as f(n) = (1, 3, 2). Participants are exploring the implications of using FFT versus Discrete Fourier Transform (DFT) for this small dataset.
  • The original poster attempts to calculate the DFT and is uncertain about the necessity of using FFT for only three points. Some participants discuss the symmetry properties of the FFT and how they might simplify calculations. Others question the equivalence of certain exponential terms in the context of periodicity.
Participants are actively engaging with the concepts of FFT and DFT, with some providing insights into the mathematical properties involved. There is a recognition of the symmetry in the function and its implications for calculations, but no explicit consensus has been reached regarding the best approach for this specific problem.
There is a focus on the mathematical properties of the exponential functions involved in the FFT calculations, particularly regarding periodicity and symmetry. The discussion reflects a learning environment where assumptions about the necessity of FFT for small datasets are being questioned.
electronic engineer
We have a set of values: f(n)=f(0,1,2)=(1,3,2)
so f(0)=1, f(1)=3, f(2)=2, where n=0,1,2the number of values N=3
The question is to calculate the FFT of this signal, the Fourier spectrum the power spectrum and phase spectrum.
I'm not sure concerning FFT. And also about the Fourier Spectrum what should I use to conduct it? the DFT or FFT?
[/B]
The calculation of DFT for these values.
I personally calculated the Discrete Fourier Transform in this way:
$$ F[n]=\sum_{k=0}^{N-1}f(k)e^{-j \frac{2\pi}{N}nk} $$
so I had a set of values: F(0),F(1),F(2)
For only 3 points, it seems unnecessary to try to do the FFT. However, the point of the FFT is to take advantage of symmetry.
F(1) = f(0) +f(1) e^{-j 2pi/N * 1 }+f(2) e^{-j 2pi/N * 2 }
F(2) = f(0) +f(1) e^{-j 2pi/N * 2 }+f(2) e^{-j 2pi/N * 4 }= f(0) +f(1) e^{-j 2pi/N * 2 }+f(2) e^{-j 2pi/N * 1 }
So whay you really have is (for real-valued inputs):
## F(0) = \pmatrix{ f(0), f(1), f(2) } \pmatrix{ 1\\1\\1} , ##
## F(1) = \pmatrix{ f(0), f(1), f(2) } \pmatrix{ 1\\ e^{-j 2\pi/N }\\ e^{ j 2\pi/N }}##
## F(2) = \pmatrix{ f(0), f(1), f(2) } \pmatrix{ 1\\ e^{j 2\pi/N }\\ e^{- j 2\pi/N }} = F(1) ^* ##
As I said, for 3 values, this is more a demonstration of the concept that F(N-k) = F(k)*, which should save you about 1 calculation by just replacing F(1) with its conjugate for F(2).
That is a very good and summarized answer. Thank you RUber :)
But I still don't understand how e^(-j*2*pi/N *2)= e^(j*2*pi/N). Are these two angles identical??
This is the symmetry of the function. ##e^{ix}## is 2pi periodic, so ##e^{ix}=e^{ix+i 2\pi}##
##e^{-j2\pi/N 2+j 2\pi}= e^{-j4\pi/3 +j6\pi/3}=e^{j*2*pi/N}.##
OK, thank you again.
