Calculating Force Exerted on a Baseball by a Pitcher
  • Thread starter Thread starter physics1234
    Baseball Force
physics1234
A baseball pitcher throws a ball straight up into the air at a speed of 21.0 m/s. In the process, he moves his hand through a distance of 1.40 m. If the ball has a mass of 0.150 kg, find the force he exerts on the ball to give it this upward speed.
My problem is that I don't know where to use the 1.40m. I assume I have to find the acceleration somehow and then plug it into F=ma but every method I try seems to fail. Thanks for the help.
What have you tried? You have the initial and final speed and the distance; that's all you need to find the acceleration. (You may need to review your kinematic equations.)
I used V^2=Vo^2 +2a(delta)x
and found acceleration to be 157.5.
then i used F=ma= (.150)*(157.5) abd got the answer to be 23.625. Apparently this is within 10% of the correct answer but not quite right. Any ideas what's wrong?
You are asked to find the force the pitcher exerted on the ball. You calculated the net force. What other force acts on the ball?
