Calculating Force on a Glockenspiel Bar Using a Dropped Ball
  • Thread starter Thread starter preston8
    Ball Force
To calculate the force needed to strike a glockenspiel bar, a wooden ball is dropped from various heights, and the impact force is derived from the ball's kinetic energy upon collision. The discussion highlights the complexities of inelastic collisions, where kinetic energy is not conserved, and emphasizes the importance of estimating impact time to determine peak force accurately. A pivoting hammer mechanism is suggested to simulate the strike, with recommendations to use video analysis for measuring the hammer's arc and rebound. Calculations indicate that the force required varies with drop height, with estimates ranging from 0.322N to 0.412N based on different heights. The final goal is to select a solenoid capable of replicating these forces for effective glockenspiel play.
preston8
Hello,
I'm looking to calculate how much force is needed to strike the bars on my glockenspiel (musical instrument).
My theory is that I can use a wooden ball of a known mass, and drop it at varying heights until the proper sound is achieved. I can then use equations that model free-falling objects (I am neglecting air resistance) to determine the amount of force the ball exerts on the bar. Is this the best way to find the force?
Here's the problem: this is an inelastic collision which means that the kinetic energy is not conserved on impact. I am not sure how to account for this loss.
Mass of ball: 2.2g
Starting height: 0.1397m (5.5 in)
End height: 0m
Initial Velocity: 0m/s
Final Velocity: ?
Elapsed time: ?
I tried "messing around" with some equations as shown below, but didn't come up with anything substantial:
Free Fall:
yf=yi + (Vy)iΔt -1/2g(Δt)2
0 = 0.1397m - 0.5*9.8*Δt2
Δt=0.169s
(Vy)f = (-9.8m/s2 * 0.1397m) = 1.37m/s
This isn't really helping me out here. Could someone set me on the right path?
Some of the energy goes into making the sound, yes.
Once you know the height to drop the ball, you can replace it with a small hammer on a pivot. How far the hammer rebounds tells you the energy that was lost in the collision ... hopefully into sounding the key.
Note: you'll get a different result with different materials for balls.
The key to this sort of thing is to start with the end in mind: what do you want to know for? This tells you what you need to calculate. The balls won't strike the bar with a single force at an instant - the force will be distributed over time. So it is unclear what "force" you want to calculate.
Hello Simon,
The force I am trying to determine will be used to select a solenoid. The solenoid will be used to hit a mallet arm near the fulcrum point. To determine which solenoid to purchase, I need to know the force.
I'm going to create the pivoting hammer. Would you suggest using a video camera to gauge the arc length that the hammer travels?
I'll post pictures of the results so that others may learn from this experience.
Preston
1. are the solenoids you are contemplating rated in units of force then?
2. you don't need the arc-length of the hammer swing - just the initial height... it's still conservation of energy to get the energy of the impact. However - the camera would help you determine how high the hammer bounces back.
Since you want the solenoid to play the thing, you'll just be using the rubber ball (or whatever) that will end up on the end of the solenoid shaft for your test?
1) Most solenoid data sheets give the maximum force. The force does vary slightly depending on the location within the stroke length.
2) I'll be using a wooden ball. The final version will use a rigid plastic ball.
1. OK - maximum force it is then. If you know the change in momentum and the impact time, you can get the peak force required (modelling as a quadratic).
I've created a video demonstrating my test.
1) The bar absorbs a majority of the energy. It only rebounds about 1/4 inch. The mallet was dropped at 89mm above the bar.
2) When you play a glockenspiel, you need to pull back the mallet arm immediately after the strike. If you let the mallet sit on the bar, it will prevent the bar from vibrating.
Ball mass: 2.2g
Arm mass: Appx 1.1g
Distance from mallet head to axis: 100mm
How would I be able to determine the impact time?
That would be the amount of time the head is in contact with the bar. I've normally used a pressure sensor - so it records force as well as time.
It sounds like about three strikes in 1/2 second, suggesting 1/4 second between strikes ... so 1/10 second impact time would be generous.
The analysis is complicated by the arm mass being significant.
If the ball starts at height ##h_1## and rebounds to height ##h_2## then:
##m_bg(h_1-h_2)+\frac{1}{2}m_ag(h_1-h_2) = \Delta E##
You may decide to neglect the rebound - since all but about 6% of the energy goes into the strike. Probably the rebound is due to the springiness of the padding since you don't get the same % loss with each bounce.
A very simple calculation would just go: $$m_b\sqrt{2gh} = \Delta p = \int_0^{\Delta t}F(t)dt$$
Where ##F(t)=\frac{4}{\Delta t^2}t(\Delta t - t)F_{peak}##
This would give an under-estimate of the force ... you could try working out a range of heights that give you a good sound so we have some idea of the tolerances involved.
The need to pull the ball away after a strike just means you need to reverse the direction of the current to the solenoid at the right time... or add a small spring to the mechanism and just deliver a pulse to the solenoid.
Thanks Simon,
Help me understand a few things here:
1) What is the difference between F(t) and Fpeak
2) What is the difference between Δt and t
I plan on utilizing a solenoid with a built-in spring return, by the way.
Preston
1. when you strike something, the force of the strike varies with time - starts zero, goes to a maximum, and then drops to zero again. F(t) is how the force varies with time, and Fpeak is the maximum force it goes to.
2. t is the time axis for the motion ... the number of microseconds or whatever since the clock started. I chose to start the clock (t=0) when the ball first touches the bar. The ball remains in contact with the bar from t=0 to t=Δt...
I worked out the integral:
$$F_{peak} = \sqrt\frac{9gh}{2}\left ( \frac{m_{eff}}{\Delta t} \right )$$
You will probably want to put ##m_{eff}=m_b+\frac{1}{2}m_a## (mass of ball plus half the mass of the arm - "half" because the center of mass of the arm is about half way along it) ... that should give you a slight over-estimate. If you put ##m_{eff}=m_b## as per the simple example above, you'll get an under-estimate.
The trick will be to estimate the contact time Δt.
The less time the ball spent in contact with the bar, the higher the peak force that was delivered. However, I suspect you don't need to be very accurate - otherwise I'll have to model how bouncy the bar support is ... and use damped harmonic motion on the way the hammer moves.
Basically the model can get as exact as you want it to be ... the trick is to get it as exact as you need it to be.
Disclaimer: I'm going off your notes here - I can help you make the decision but I cannot make the decision for you. I will not take responsibility if you buy a less than ideal solenoid: price of "free" science work.
Simon,
Here's the value I have reached:
\sqrt{9*9.8*0.089m/2}* (0.0022kg + 0.5 * 0.0011kg)
Result: 0.0054N
That's about 1/1000 of a pound. Does that make sense?
Would an estimate be easier to arrive at if we assumed that we were simply dropping the ball (no arm attached) from a set height and assumed that all of the energy was absorbed by the bar?
It sounds good from 90-140mm above the bar.
I would of made it really simple by just treating it as a dropped ball. F = mdv/dt. You know the mass, you can calculate the final velocity easily from that and the drop height, and the contact time from a video of the test. You could slow the video down and calculate it if you know the frame rate of the camera. Although, I like Simon's estimate, that would be about right for an ineslastic object. Simon's is pretty much the same though.
That's pretty much what I did.
The point of attaching the ball to an arm was to get an estimate of how much gravitational PE got turned into sound ... but we saw that pretty much all of it did.
Note: I don't see a value for Δt in there: you are effectively assuming an impact time of one second. If we say Δt=0.1s the Fpeak=0.054N ... if Δt=0.01s then it's 0.54N ... you can get an idea what is reasonable by tapping it against your hand and comparing with hefting the masses. The wooden hammer does not hit very hard does it?
You could also try hitting a sensitive electronic balance with a hammer - though that usually doesn't work well since it takes the balance a while to react.
What we are doing with the Fpeak is working out what sort of impact profile the solenoid needs to reproduce the impact energy of the dropped ball. So you should really use the Δt for the solenoid there.
I analyzed the audio from the video and I believe that the impact time is considerably shorter than 1/10 second. As you can see in the waveform, the metallic "ting" sound lasts only for about 0.018 seconds. I believe that the initial ting sound is the impact, and the rest of the waveform is simply the reverberation of the bar.
http://ubuilds.com/wp-content/uploads/2012/09/Untitled.jpg
I re-calculated and got some numbers that seem reasonable.
Δt = 0.018s
102mm above bar: 0.322N (32.3g)
130mm above bar: 0.366N (36.6g)
165mm above bar 0.412N (41.2g)
Oh that's good!
Shows what can happen with collaboration.
If the solenoids are rated in lbs, then 0.008-0.01lbs would seem fair.
Hey thanks.
I'd like to clarify the poundage calculations. I believe 1N = 0.2248 pound
102mm above bar: 0.322N (32.3g) = 0.072lb
130mm above bar: 0.366N (36.6g) = 0.083lb
165mm above bar 0.412N (41.2g) = 0.093lb
I'd like to keep this thread alive with another question. I've looked over my physics book to review torques and equilibrium and believe I have setup the following problem correctly.
Basically, I want to find out approximately how much force is translated to the tip of the mallet.
Would Simon or someone else mind looking this over?
Thanks
http://ubuilds.com/myPhotos/ScannedImage-3_Small.jpg
Presumably you have a spring holding the mallet head above the bar ready to strike?
You could hinge the mallet at the end of the shaft and strike it from above 15mm in ;) (Also let's you vary the lever arm to fine-tune the effect.)
If you want to use the lever to amplify the force, then you need to get the mallet head on the short part of the lever.
But see: http://en.wikipedia.org/wiki/Hammer
The mallet head needs to be moving at an adequate speed during impact. To get the speed, I need to mount the solenoid very close to the fulcrum. I understand that I will need to get a solenoid that is powerful enough to deliver 0.5N of force. This may require a solenoid with force equivalent to 1.4N or greater.
I'd like to ask you where you believe I should place the W.
Also, you're right in that I will have a spring that holds the mallet above the bar. The spring will be built into the solenoid. To "hold" onto the mallet, the solenoid's shaft will have a ball on the end that fits into a groove on the back of the mallet.
See the wiki link about how a hammer/lever setup amplifies the speed.
The calculation is very similar to the one I did using the energy of the impact.
