Calculating Force to Tip a Box Dragged Across Floor
  • Thread starter Thread starter Shiz
    Box Force
2 replies · 8K views
Shiz
A box is being dragged across the floor with a rope that is h distance above the floor. The coefficient of friction is 0.35. The box is 0.50m high and 0.25m wide. Find the force that just tips the box.
Ff=uMg=3.43m/s2M
Fg=Mg=9.80m/s2M
Well,...that's about it.
I don't understand the problem enough to draw a force/torque diagram! But I do know that h and M are going to be unknown variables.
on Phys.org
There are two forces of interest.
The weight acting through the center of mass.
The force acting at height h.
So when the force moment, F * h is greater than m*g*width/2 acting down, it should tip about the leading corner right?
The problem should identify the mass of the box as M. Then M and h are given variables. F (the applied tipping force) is the unknown variable. I don't know why the problem left out the "M". But note that since the block is sliding and has overcome static friction without tipping, it must be accelerating. It can't be moving at constant speed at the 'tip over' point. The solution requires the use of simultaneous eqations involving sum of torques =0 , including the torque from the pseudo inertial force acting at the c.g (which is also not given) , and sum of forces in x direction, including the pseudo inertial force acting at the c.g , = 0. Poorly worded problem when you have to make your own assumptions.
